Hello.
When i try to compile my programm that i imported from Arduino i get this error:
object of abstract class type “WiFiUDP” is not allowed: – pure virtual function “UDP::remoteIP” has no overrider – pure virtual function “UDP::remotePort” has no overrider
and many more e.g. this:
error: invalid abstract return type for member function ‘WiFiClient WiFiServer::available(uint8_t*)’
Is there a Problem with the WiFi class in PlatfromIO because it is working in Arduino IDE.
This is the beginning of the programm:
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include <ESP8266WiFi.h>
#include <WiFi.h>
#include <TimeLib.h>
#include <WiFiUdp.h>
WiFiClient client;
WiFiUDP udp;
The Problem is WifiUDP udp; VSC marks this red.
The whole errore looks like this
> Executing task in folder 190414-164233-d1_mini: C:\Users\User\.platformio\penv\Scripts\platformio.exe run --target upload <
_Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)_
_-----------------------------------------------------------------------------------------------------------------------------------------------_
_Verbose mode can be enabled via `-v, --verbose` option_
_CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html_
_PLATFORM: Espressif 8266 > WeMos D1 R2 and mini_
_HARDWARE: ESP8266 80MHz 80KB RAM (4MB Flash)_
_Converting bildschrim.ino_
_Library Dependency Finder -> http://bit.ly/configure-pio-ldf_
_LDF MODES: FINDER(chain) COMPATIBILITY(soft)_
_Collected 34 compatible libraries_
_Scanning dependencies..._
_Dependency Graph_
_|-- <Adafruit MQTT Library> 0.20.4_
_|-- <ESP8266WebServer> 1.0_
_| |-- <WiFi> 1.2.7_
_| | |-- <SPI> 1.0_
_| |-- <ESP8266WiFi> 1.0_
_|-- <WiFi> 1.2.7_
_| |-- <SPI> 1.0_
_|-- <Adafruit GFX Library> 1.4.9_
_| |-- <SPI> 1.0_
_|-- <Time> 1.5_
_|-- <ESP8266WiFi> 1.0_
_|-- <SPI> 1.0_
_|-- <Adafruit ST7735 and ST7789 Library> 1.2.8_
_| |-- <SPI> 1.0_
_| |-- <Adafruit GFX Library> 1.4.9_
_| | |-- <SPI> 1.0_
_Compiling .pioenvs\d1_mini\src\bildschrim.ino.cpp.o_
_Compiling .pioenvs\d1_mini\lib204\WiFi_ID870\WiFi.cpp.o_
_Compiling .pioenvs\d1_mini\lib204\WiFi_ID870\WiFiClient.cpp.o_
_Compiling .pioenvs\d1_mini\lib204\WiFi_ID870\WiFiServer.cpp.o_
_Compiling .pioenvs\d1_mini\lib204\WiFi_ID870\WiFiUdp.cpp.o_
_In file included from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFi.h:32:0,_
_from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFi.cpp:21:_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.h:37:14: error: invalid abstract return type for member function 'WiFiClient WiFiServer::available(uint8_t*)'_
_WiFiClient available(uint8_t* status = NULL);_
_^_
_In file included from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFi.h:31:0,_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiClient.h:27:7: note: because the following virtual functions are pure within 'WiFiClient':_
_class WiFiClient : public Client {_
_^_
_In file included from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiClient.h:24:0,_
_from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFi.h:31,_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Client.h:29:21: note: virtual int Client::connect(const IPAddress&, uint16_t)_
_virtual int connect(CONST IPAddress& ip, uint16_t port) =0;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Client.h:37:22: note: virtual bool Client::flush(unsigned int)_
_virtual bool flush(unsigned int maxWaitMs = 0) = 0;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Client.h:38:22: note: virtual bool Client::stop(unsigned int)_
_virtual bool stop(unsigned int maxWaitMs = 0) = 0;_
_^_
_from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiClient.cpp:27:_
_^_
_^_
_^_
_^_
_^_
_from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:27:_
_^_
_^_
_^_
_^_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp: In member function 'WiFiClient WiFiServer::available(byte*)':_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:47:12: error: invalid abstract return type for member function 'WiFiClient WiFiServer::available(byte*)'_
_WiFiClient WiFiServer::available(byte* status)_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiClient.h:27:7: note: since type 'WiFiClient' has pure virtual functions_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:56:21: error: cannot declare variable 'client' to be of abstract type 'WiFiClient'_
_WiFiClient client(sock);_
_^_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:72:24: error: cannot allocate an object of abstract type 'WiFiClient'_
_return client; //TODO_
_^_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:77:26: error: cannot allocate an object of abstract type 'WiFiClient'_
_return WiFiClient(255);_
_^_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp: In member function 'virtual size_t WiFiServer::write(const uint8_t*, size_t)':_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:98:21: error: cannot declare variable 'client' to be of abstract type 'WiFiClient'_
_^_
_^_
_C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiServer.cpp:78:1: warning: control reaches end of non-void function [-Wreturn-type]_
_}_
_^_
_C:/Users/User/Documents/PlatformIO/Projects/190414-164233-d1_mini/src/bildschrim.ino:17:1: error: 'f' does not name a type_
_char *ssid = "WLANSSID"; // Set you WiFi SSID_
_^_
_In file included from C:/Users/User/Documents/PlatformIO/Projects/190414-164233-d1_mini/src/bildschrim.ino:21:0:_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:32:27: error: expected class-name before ',' token_
_class WiFiUDP : public UDP, public SList<WiFiUDP> {_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:78:16: error: type 'Print' is not a base type for type 'WiFiUDP'_
_using Print::write;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:46:11: error: 'uint8_t WiFiUDP::begin(uint16_t)' marked override, but does not override_
_uint8_t begin(uint16_t port) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:48:8: error: 'void WiFiUDP::stop()' marked override, but does not override_
_void stop() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:56:7: error: 'int WiFiUDP::beginPacket(IPAddress, uint16_t)' marked override, but does not override_
_int beginPacket(IPAddress ip, uint16_t port) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:59:7: error: 'int WiFiUDP::beginPacket(const char*, uint16_t)' marked override, but does not override_
_int beginPacket(const char *host, uint16_t port) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:72:7: error: 'int WiFiUDP::endPacket()'_
_marked override, but does not override_
_int endPacket() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:74:10: error: 'size_t WiFiUDP::write(uint8_t)' marked override, but does not override_
_size_t write(uint8_t) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:76:10: error: 'size_t WiFiUDP::write(const uint8_t*, size_t)' marked override, but does not override_
_size_t write(const uint8_t *buffer, size_t size) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:82:7: error: 'int WiFiUDP::parsePacket()' marked override, but does not override_
_int parsePacket() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:84:7: error: 'int WiFiUDP::available()'_
_int available() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:86:7: error: 'int WiFiUDP::read()' marked override, but does not override_
_int read() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:89:7: error: 'int WiFiUDP::read(unsigned char*, size_t)' marked override, but does not override_
_int read(unsigned char* buffer, size_t len) override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:92:7: error: 'int WiFiUDP::read(char*, size_t)' marked override, but does not override_
_int read(char* buffer, size_t len) override { return read((unsigned char*)buffer, len); };_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:94:7: error: 'int WiFiUDP::peek()' marked override, but does not override_
_int peek() override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:95:8: error: 'void WiFiUDP::flush()' marked override, but does not override_
_void flush() override; // Finish reading the current packet_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:98:13: error: 'IPAddress WiFiUDP::remoteIP() const' marked override, but does not override_
_IPAddress remoteIP() const override;_
_^_
_C:\Users\User\.platformio\packages\framework-arduinoespressif8266\libraries\ESP8266WiFi\src/WiFiUdp.h:100:12: error: 'uint16_t WiFiUDP::remotePort() const' marked override, but does not override_
_uint16_t remotePort() const override;_
_^_
_from C:\Users\User\.platformio\lib\WiFi_ID870\src\WiFiUdp.cpp:28:_
_^_
_^_
_^_
_^_
_^_
_C:/Users/User/Documents/PlatformIO/Projects/190414-164233-d1_mini/src/bildschrim.ino:33:14: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]_
_Adafruit_MQTT_Subscribe Feuchte= Adafruit_MQTT_Subscribe(&mqtt, "/weatherStation/humidity");_
_^_
_C:/Users/User/Documents/PlatformIO/Projects/190414-164233-d1_mini/src/bildschrim.ino:35:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]_
_void MQTT_connect();_
_^_
_Compiling .pioenvs\d1_mini\FrameworkArduino\core_esp8266_wiring_analog.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\core_esp8266_wiring_digital.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\core_esp8266_wiring_pulse.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\core_esp8266_wiring_pwm.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\core_esp8266_wiring_shift.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\debug.cpp.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\gdb_hooks.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\heap.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\libb64\cdecode.c.o_
_Compiling .pioenvs\d1_mini\FrameworkArduino\libb64\cencode.c.o_
_*** [.pioenvs\d1_mini\lib204\WiFi_ID870\WiFi.cpp.o] Error 1_
_*C** [.pioenvs\d1_mini\lib204\WiFi_ID870\WiFiClient.cpp.o] Error 1ompiling .pioenvs\d1_mini\FrameworkArduino\libc_replacements.c.o_
_*** [.pioenvs\d1_mini\lib204\WiFi_ID870\WiFiServer.cpp.o] Error 1_
_*** [.pioenvs\d1_mini\lib204\WiFi_ID870\WiFiUdp.cpp.o] Error 1_
_*** [.pioenvs\d1_mini\src\bildschrim.ino.cpp.o] Error 1_
_========================================================== [ERROR] Took 2.80 seconds ==========================================================_
_The terminal process terminated with exit code: 1_
