Why is my struct syntax always causing errors when compiled?
This is my struct definition and declaration, I clearly wrote it according to C syntax, why do I keep getting errors?
typedef enum{
    Rx_Idle,
    Rx_Running,
    Rx_End,
    Rx_Overflow
}UartState_t;
typedef struct
    u8 rx_buf[RX_BUFFER_SIZE];
    u8 rx_len;
    UartState_t state;
}Uart_t;
Uart_t Uart1
    {0},
    0,
    Rx_Idle
This is an error message
error 1: Syntax error, declaration ignored at 'Uart1'
syntax error: token -> '}' ;column 7
Possibly the semicolon after UartState_t state;?
Cheers,
Norm.
What about this error below:
lib/uart/uart.h:26: syntax error: token -> '}' ; column 1
*** [.pio\build\STC89C52RC\src\main.rel] Error 1
lib\uart\/uart.h:26: syntax error: token -> '}' ; column 1
*** [.pio\build\STC89C52RC\lib1a3\uart\uart.rel] Error 1
This is code:
typedef struct
    u8 rx_len;
    UartState_t state
}Uart_t;
Uart_t Uart1
    {0},
    0,
    Rx_Idle
I have found the error, it’s not about the ; error, Instead, should add = to the end of the struct, which is the code:
typedef struct
    u8 rx_len;
    UartState_t state;
}Uart_t;
Uart_t Uart1 =
    {0},
    0,
    Rx_Idle
Good spot. Better than mine! :wink:
Cheers,
Norm.
