If there is a change in platformio.ini or in dependencies in a library.json from a private library, the pio lib update command will not install those new dependencies automatically, but i have to run pio lib install separately.
Why is this?
I would also like to have an option with pio lib update to remove any libraries in lib_deps that are no longer in the dependency tree. Is this possible?
