@normandunbar here you go.
// @section leveling
* Points to probe for all 3-point Leveling procedures.
* Override if the automatically selected points are inadequate.
#if EITHER(AUTO_BED_LEVELING_3POINT, AUTO_BED_LEVELING_UBL)
//#define PROBE_PT_1_X 15
//#define PROBE_PT_1_Y 180
//#define PROBE_PT_2_X 15
//#define PROBE_PT_2_Y 20
//#define PROBE_PT_3_X 170
//#define PROBE_PT_3_Y 20
* Probing Margins
* Override PROBING_MARGIN for each side of the build plate
* Useful to get probe points to exact positions on targets or
* to allow leveling to avoid plate clamps on only specific
* sides of the bed. With NOZZLE_AS_PROBE negative values are
* allowed, to permit probing outside the bed.
* If you are replacing the prior *_PROBE_BED_POSITION options,
* LEFT and FRONT values in most cases will map directly over
* RIGHT and REAR would be the inverse such as
* (X/Y_BED_SIZE - RIGHT/BACK_PROBE_BED_POSITION)
* This will allow all positions to match at compilation, however
* should the probe position be modified with M851XY then the
* probe points will follow. This prevents any change from causing
* the probe to be unable to reach any points.
#if PROBE_SELECTED && !IS_KINEMATIC
#define PROBING_MARGIN_LEFT PROBING_MARGIN 46
#define PROBING_MARGIN_RIGHT PROBING_MARGIN 46
#define PROBING_MARGIN_FRONT PROBING_MARGIN 20
#define PROBING_MARGIN_BACK PROBING_MARGIN 20
#if EITHER(MESH_BED_LEVELING, AUTO_BED_LEVELING_UBL)
// Override the mesh area if the automatic (max) area is too large
//#define MESH_MIN_X MESH_INSET
//#define MESH_MIN_Y MESH_INSET
//#define MESH_MAX_X X_BED_SIZE - (MESH_INSET)
//#define MESH_MAX_Y Y_BED_SIZE - (MESH_INSET)
