This is one of the things that can go wrong. I don’t think I’ve seen anything like this with an Arduino, but this is a DOIT Devkit ESP32.
I’ve seen similar or maybe even identical stuff.
This script was working when I put it away, but now it’s not.
I don’t want to fix the script. There’s some struct stuff being received via ESP Now, and it has to be rebuilt from the example.
Looks like I’ll need more than one struct. Boo.
There’s a meditation thing, a panic, a register dump… I’d just like to know what I’m seeing. This grid, what is it?
Thank you.
> Executing task in folder ESPNow_Random_Receiver_DOIT: C:\Users\joema\.platformio\penv\Scripts\pio.exe device monitor <
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at http://bit.ly/pio-monitor-filters
--- Miniterm on COM7 9600,8,N,1 ---
Packet received from: 8c:aa:b5:8c:68:8c
Board ID 1: 12 bytes
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4000c3f0 PS : 0x00060830 A0 : 0x800d20de A1 : 0x3ffb53d0
A2 : 0x3ffafe04 A3 : 0x004c4a00 A4 : 0x00000089 A5 : 0x3f4010a1
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000000 A9 : 0x004c4a00
A10 : 0x00000001 A11 : 0x059e3084 A12 : 0x3ffc1600 A13 : 0x059e3084
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000004 EXCCAUSE: 0x0000001c
EXCVADDR: 0x004c4a00 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
Backtrace: 0x4000c3f0:0x3ffb53d0 0x400d20db:0x3ffb53f0 0x400d211b:0x3ffb5410 0x400d0f8a:0x3ffb5430 0x40125dd1:0x3ffb5480 0x400f91e7:0x3ffb54a0 0x400f90c8:0x3ffb54d0 0x400f517d:0x3ffb5500 0x400f5311:0x3ffb5640 0x40134051:0x3ffb5660 0x4008f5b6:0x3ffb56b0 0x40088b7d:0x3ffb56f0
Rebooting...
