What causes Error 1? | ESP32S2 Error 1
When uploading a script to an esp32-s2 it will upload correctly to the board (i can tell because it’s only a blink script) but I get an error 1 reported with verbose upload:
Processing custom-esp32 (platform: espressif32; board: ESP32-S2-SOLO-2-N4; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/ESP32-S2-SOLO-2-N4.html
PLATFORM: Espressif 32 (6.4.0) > ESP32-S2-SOLO-2-N4
HARDWARE: ESP32S2 240MHz, 320KB RAM, 4MB Flash
 - framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
 - tool-mkfatfs @ 2.0.1
 - toolchain-xtensa-esp32s2 @ 8.4.0+2021r2-patch5
Found 33 compatible libraries
<lambda>(["checkprogsize"], [".pio/build/custom-esp32/firmware.elf"])
MethodWrapper(["checkprogsize"], [".pio/build/custom-esp32/firmware.elf"])
RAM:   [          ]   4.4% (used 14560 bytes from 327680 bytes)
Flash: [==        ]  17.2% (used 225390 bytes from 1310720 bytes)
.pio/build/custom-esp32/firmware.elf  :
section        size         addr
.rtc.text        0   1074200576
.rtc.dummy        0   1073340416
.rtc.force_fast        0   1073340416
.rtc_noinit        16   1342177280
.rtc.force_slow        0   1342177296
.iram0.vectors        1027   1073889280
.iram0.text        45736   1073890308
.dram0_reserved_for_iram                                                              46764   1073430528
.dram0.data        9976   1073477296
.noinit        0   1073487272
.ext_ram.bss        0   1062207488
.dram0.bss        4584   1073487272
.flash.appdesc        256   1056964640
.flash.rodata        45020   1056964896
.flash.rodata_noload        0   1057009916
.flash.text        123631   1074266144
.iram0.text_end        0   1073936044
.dram0.heap_start        0   1073491856
.xt.prop        141396            0
.xt.lit        4160            0
.xtensa.info        56            0
.comment        102            0
.xt.lit._ZN3nvs4Lock4initEv                                                               0            0
.xt.prop._ZN3nvs4Lock4initEv                                                             72            0
.xt.lit._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv          0            0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv       108            0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE9push_backEPS2_              60            0
.xt.lit._ZN3nvs12NVSPartitionD5Ev                                                         0            0
.xt.prop._ZN3nvs12NVSPartitionD5Ev                                                        0            0
.xt.prop._ZN3nvs12NVSPartitionD2Ev                                                       36            0
.xt.prop._ZN3nvs12NVSPartitionD0Ev                                                       36            0
.xt.prop._ZTVN3nvs12NVSPartitionE                                                        12            0
.xt.lit._ZN3nvs19NVSPartitionManagerD5Ev                                                  0            0
.xt.prop._ZN3nvs19NVSPartitionManagerD5Ev                                                 0            0
.xt.prop._ZN3nvs19NVSPartitionManagerD2Ev                                                36            0
.xt.prop._ZN3nvs19NVSPartitionManagerD0Ev                                                36            0
.xt.prop._ZN14intrusive_listIN3nvs12NVSPartitionEE5eraseENS2_8iteratorE                  84            0
.xt.prop._ZTVN3nvs19NVSPartitionManagerE                                                 12            0
.xt.prop._ZN14intrusive_listIN3nvs8HashList13HashListBlockEE5eraseENS3_8iteratorE        84            0
.xt.lit._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch                                                0            0
.xt.prop._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch                                               0            0
.xt.prop._ZN3nvs20isVariableLengthTypeENS_8ItemTypeE                                     48            0
.xt.prop._ZN3nvs4ItemC2EhNS_8ItemTypeEhPKch                                              60            0
.xt.prop._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEjPS2_          48            0
.xt.lit._ZN14intrusive_listIN3nvs4PageEE5clearEv                                          0            0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5clearEv                                        60            0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE9push_backEPS1_                                 60            0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5eraseENS2_8iteratorE                           84            0
.xt.lit._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv                                   8            0
.xt.lit._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv                                 8            0
.xt.lit._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev                                       8            0
.xt.lit._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev                                     8            0
.xt.lit._ZN9__gnu_cxx7__mutex4lockEv                                                      8            0
.xt.lit._ZN9__gnu_cxx13__scoped_lockD5Ev                                                  8            0
.xt.prop._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv                                 48            0
.xt.prop._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv                               48            0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev                                     12            0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev                                   12            0
.xt.prop._ZN9__gnu_cxx7__mutex4lockEv                                                    48            0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD5Ev                                                12            0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD2Ev                                     36            0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD2Ev                                   36            0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD0Ev                                     36            0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD0Ev                                   36            0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD2Ev                                                72            0
.xt.prop._ZTISt9exception        12            0
.xt.prop._ZTIN9__gnu_cxx24__concurrence_lock_errorE                                      12            0
.xt.prop._ZTIN9__gnu_cxx26__concurrence_unlock_errorE                                    12            0
.xt.prop._ZTVN9__gnu_cxx24__concurrence_lock_errorE                                      12            0
.xt.prop._ZTVN9__gnu_cxx26__concurrence_unlock_errorE                                    12            0
.xt.prop._ZTISt9bad_alloc        12            0
.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE                                        12            0
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE                                           12            0
.debug_frame        55920            0
.debug_info        2857992            0
.debug_abbrev        237394            0
.debug_aranges        22440            0
.debug_ranges        62776            0
.debug_line        1062719            0
.debug_str        263963            0
.debug_loc        465140            0
Total        5452544
<lambda>(["upload"], [".pio/build/custom-esp32/firmware.bin"])
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
BeforeUpload(["upload"], [".pio/build/custom-esp32/firmware.bin"])
Auto-detected: /dev/cu.usbmodem01
"/Users/freddy/.platformio/penv/bin/python" "/Users/freddy/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32s2 --port "/dev/cu.usbmodem01" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 "/Users/freddy/Library/Mobile Documents/com~apple~CloudDocs/Code/Arduino/Test-Blink/.pio/build/custom-esp32/bootloader.bin" 0x8000 "/Users/freddy/Library/Mobile Documents/com~apple~CloudDocs/Code/Arduino/Test-Blink/.pio/build/custom-esp32/partitions.bin" 0xe000 /Users/freddy/.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin 0x10000 .pio/build/custom-esp32/firmware.bin
esptool.py v4.5.1
Serial port /dev/cu.usbmodem01
Connecting....
Chip is ESP32-S2 (revision v1.0)
Features: WiFi, No Embedded Flash, No Embedded PSRAM, ADC and temperature sensor calibration in BLK2 of efuse V2
Crystal is 40MHz
MAC: a0:76:4e:8c:57:56
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00004fff...
Flash will be erased from 0x00010000 to 0x00047fff...
Compressed 14720 bytes to 10221...
Writing at 0x00001000... (20 %)
Writing at 0x00001c5a... (40 %)
Writing at 0x000027ac... (60 %)
Writing at 0x000032d6... (80 %)
Writing at 0x00003c4c... (100 %)
Wrote 14720 bytes (10221 compressed) at 0x00001000 in 0.2 seconds (effective 523.4 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 472.4 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 753.3 kbit/s)...
Compressed 225760 bytes to 127079...
Writing at 0x00010000... (1 %)
- [TRUNCATED]
Writing at 0x00046500... (98 %)
Writing at 0x00047147... (100 %)
Wrote 225760 bytes (127079 compressed) at 0x00010000 in 2.1 seconds (effective 877.2 kbit/s)...
Leaving...
WARNING: ESP32-S2 (revision v1.0) chip was placed into download mode using GPIO0.
esptool.py can not exit the download mode over USB. To run the app, reset the chip manually.
To suppress this note, set --after option to 'no_reset'.
*** [upload] Error 1
Is this simply because the board is in boot mode?
What does error 1 mean?
How can I resolve this error?
Is there a specific reason for this outdated version and does the error also occur with the current version (6.7.0)?
No specific reason, I never realised it was outdated. I updated to 6.7.0 and got the same behaviour
Please share your platformio.ini and a basic sketch to reproduce this.
Also perform a full clean.
Performed full clean and got the same result. I am using environment [env:custom-esp32]
platformio.ini
[env:esp32-S2]
# platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#esp32s2
board = esp32-s2-saola-1
board_build.mcu = esp32s2
debug_tool = esp-prog
[env:custom-esp32]
board = ESP32-S2-SOLO-2-N4
Custom board .json
    "build": {
        "f_cpu": "240000000L",
        "f_flash": "80000000L",
        "hwids": [
                "0x303A",
                "0x0002"
        "core": "esp32",
        "extra_flags": "-DARDUINO_ESP32S2_DEV",
        "flash_mode": "qio",
        "mcu": "esp32s2",
        "variant": "esp32s2"
    "debug": {
        "openocd_target": "esp32s2.cfg"
    "frameworks": [
        "arduino",
        "espidf"
    "name": "ESP32-S2-SOLO-2-N4",
    "upload": {
        "flash_size": "4MB",
        "maximum_ram_size": 327680,
        "maximum_size": 4194304,
        "require_upload_port": true,
        "speed": 460800
    "url": "https://www.espressif.com/sites/default/files/documentation/esp32-s2-solo-2_esp32-s2-solo-2u_datasheet_en.pdf",
    "vendor": "Espressif"
Simple header include/ESP32-S2-SOLO-2-N4.hpp
#define LED_BUILTIN_1 1
#define LED_BUILTIN_2 2
main.cpp
#include "ESP32-S2-SOLO-2-N4.hpp"
// the setup function runs once when you press reset or power the board
void setup()
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN_1, OUTPUT);
  pinMode(LED_BUILTIN_2, OUTPUT); // Second built in LED
// the loop function runs over and over again forever
void loop()
  digitalWrite(LED_BUILTIN_1, HIGH); // turn the LED on (HIGH is the voltage level)
  digitalWrite(LED_BUILTIN_2, LOW);
  delay(1000); // wait for a second
  digitalWrite(LED_BUILTIN_1, LOW); // turn the LED off by making the voltage LOW
  digitalWrite(LED_BUILTIN_2, HIGH);
  delay(1000);
I’ve just swapped to using an esp-prog to upload the code via jtag. It does everything I need and it returns a success code.
