Weird multiple definition message
No, just remove the text encSwitch after the struct declaration as to not create a variable of that struct directly.
struct EncSwitch
  const uint8_t pinSW  = 13;
  const uint8_t pinCLK = 26;
  const uint8_t pinDT  = 27;
  uint16_t totalPress  = 0;
  uint16_t maxEncCount = 0;
  volatile uint16_t curEncCount  = 0;
  volatile uint16_t oldEncCount  = 0;
  volatile uint16_t deBounceTime = 300;
  bool swPressed = false;
} encSwitch;
^ declares the structure and directly instantiates one with the name encSwitch → if included from multiple .cpp files, will create multiple definitions → bad
struct EncSwitch
^ just declares the EncSwitch structure, which is what you need.
You’re right, this has to be treated the same way. extern in the header and without init value, and then no extern and with init value in one .cpp file.
