Hello. I use a library which in one header defines a TEMPLATE_PLACEHOLDER. (with check ifndef). I want to change this placeholder to another value. I’ve tried:
- using #define TEMPLATE_PLACEHOLDER ‘|’ in main.cpp before the import
- using #define TEMPLATE_PLACEHOLDER ‘|’ in main.cpp after the import (gives an overwrite warning)
- using #ifdef TEMPLATE_PLACEHOLDER #undef TEMPLATE_PLACEHOLDER #define TEMPLATE_PLACEHOLDER
- usind #undef TEMPLATE_PLACEHOLDER #define TEMPLATE_PLACEHOLDER
All versions do not change the actual placeholder.
only working version is if i change directly the library header file.
What can i do?
This also depends on the library code. E.g., if the library does in the header file
#define MACRO 123
without checking if it’s previously defined (#ifndef MACRO
…), you can’t overwrite it from my understanding, except for changing the code.
Note that when the macro is used in the library’s implementation .cpp
file, it won’t be affected by whatever you put in main.cpp
, since it’s a different compilation unit.
So, you should define the flag globally using the define build_flags
option, with e.g.
-D TEMPLATE_PLACEHOLDER='|'
in the platformio.ini
I’ve tried that, but this leads to an error “The command “-DESP32” is either wrong or could not be found”.
Processing esp-wrover-kit (platform: espressif32; board: esp-wrover-kit; framework: arduino)
CONFIGURATION:...
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
LDF: Library Dependency Finder -> ...
Found 32 compatible libraries
|-- <WiFi> 1.0
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <AsyncElegantOTA> 2.2.5
| |-- <AsyncTCP> 1.1.1
| | |-- <AsyncTCP> 1.1.1
| | |-- <FS> 1.0
| | |-- <WiFi> 1.0
| |-- <FS> 1.0
| |-- <Update> 1.0
| |-- <WiFi> 1.0
|-- <AsyncTCP> 1.1.1
Compiling .pio\build\esp-wrover-kit\src\main.cpp.o
Generating partitions .pio\build\esp-wrover-kit\partitions.bin
Der Befehl "-DESP32" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\ETH.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFi.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp-wrover-kit\lib79f\WiFi\WiFiUdp.cpp.o
*** [.pio\build\esp-wrover-kit\src\main.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\ETH.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFi.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiAP.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiClient.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiGeneric.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiMulti.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiSTA.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiScan.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiServer.cpp.o] Error 255
*** [.pio\build\esp-wrover-kit\lib79f\WiFi\WiFiUdp.cpp.o] Error 255
I’ve used the following platformio.ini:
[env:esp-wrover-kit]
board = esp-wrover-kit
upload_port = COM7
board_build.partitions = min_spiffs.csv
monitor_port = COM7
; -U TEMPLATE_PLACEHOLDER
;lib_ldf_mode = chain+
WiFi
ESP Async WebServer
ayushsharma82/AsyncElegantOTA @ ^2.2.5
Library ESP Async Webserver makes the problem.
#include "Arduino.h"
// #include "SPI.h"
// #include "WiFiMulti.h"
// #include <SD.h>
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
AsyncWebServer server(80);
The rest is like the example at ESP32 Async Web Server – Control Outputs | Random Nerd Tutorials (sorry i can’t post the link) only with a css code that contaisn size 100% etc. Since % is the default template placeholder, i wanted to change this.
The library uses
#ifndef TEMPLATE_PLACEHOLDER
so that should be ok…
Oh yeah there is some weird transformation going on so it needs escaping. When trying this on the commandline for normal GCC, the invocation
gcc -D"TEMPLATE_PLACEHOLDER='|'" -o temp temp.c
does the trick, but not in PlatformIO, because of shell escaping… somehow screwing up with the quotes. The workaround is to represent chars by their ASCII numeral value and a cast to char.
-D"TEMPLATE_PLACEHOLDER=\(char\)124"
should work.
Worked without the escape characters:
-D"TEMPLATE_PLACEHOLDER=(char)124"
