Hi Guys,
So I need to get --baud=
onto the command line when running from VSCode.
So manually I can get it going like this:
pio debug -q --directory /Users/bob/.platformio/.cache/.piodebug-qc_d4a9f --directory /Users/bob/Development/teensy/TeensyTest -l 10 --baud=115200 -x .pioinit /Users/bob/Development/teensy/TeensyTest/.pio/build/teensy41/firmware.elf
When running from VSCode even with debug_speed = 115200
set I get this:
pio debug -q --directory /Users/bob/.platformio/.cache/.piodebug-l0ur2y2e --directory /Users/bob/Development/teensy/TeensyTest -l 10 --interpreter=mi2 -q /Users/bob/Development/teensy/TeensyTest/.pio/build/teensy41/firmware.elf
So the baud rate is not being set.
I’m banging my head against the wall here as this seems a simple thing but I just can’t find any info on it.
here is the PlatformIO stuff:
[env:teensy41]
platform = teensy
board = teensy41
monitor_port = /dev/cu.usbmodem79500901
build_type = debug
lib_deps = https://github.com/ftrias/TeensyDebug/archive/refs/heads/master.zip
build_unflags = -DUSB_SERIAL
build_flags = -DUSB_DUAL_SERIAL
-DDEBUG # Comment out to disable debugging.
debug_port = /dev/cu.usbserial-14410 # Teensy, computer and OS dependent -- NEEDS TO BE ADJUSTED
debug_tool = custom
debug_load_mode = manual
debug_server =
debug_init_cmds =
target extended-remote $DEBUG_PORT
$INIT_BREAK
define pio_reset_run_target
interrupt
tbreak loop
continue
end
define pio_restart_target
echo Restart is undefined for now.
end
debug_init_break =
Anyone got any hints it would really be appreciated.
Thanks
Andy
