Hi so I just started with Visual Studio ( I used the Arduino IDE before),
and i have a problem that the Serial Monitor is not showing anything.
It just shows the baud rate I set and the USB port.
(btw Idk if its weird or not but the port is /dev/ttyACM0??)
i use a Teensy 3.5 board. It uploads just find but does not do anything in the Serial Monitor.
I already tried:
pio device monitor --encoding hexlify
and
pio device monitor --filter debug
but none of it works.
Weirdly it worked one time when I tried both and then Restarted the IDE. But second time i uploaded it, it stopped working again.
