Platformio’s library registry version of OpenWeatherOneCall is 2.0.2. According to a reply with the maintainer, it seems the issue is on the library repo side:
The library.json
manifest contains an unknown key board
that may cause the PIO registry to reject the library.
CC ivankravets, https://platformio.org/lib/show/7247/OpenWeatherOneCall
Okay no the library manifest is definitely unparsable with an additional error in the repository
field, when doing a global library install of the git version, it immediately crashes because repository
is supposed to be one object, not an array (docs).
>pio lib -g install https://github.com/JHershey69/OpenWeatherOneCall/archive/refs/heads/master.zip
Library Storage: C:\Users\Max\.platformio\lib
Library Manager: Installing https://github.com/JHershey69/OpenWeatherOneCall/archive/refs/heads/master.zip
Downloading...
File "c:\users\max\appdata\local\programs\python\python38\lib\site-packages\platformio\package\manifest\parser.py", line 155, in __init__
self._data = self.normalize_repository(self._data)
File "c:\users\max\appdata\local\programs\python\python38\lib\site-packages\platformio\package\manifest\parser.py", line 213, in normalize_repository
url = (data.get("repository") or {}).get("url")
AttributeError: 'list' object has no attribute 'get'
Until the fix is merged, please include the fixed fork of the library as follows in the platformio.ini
https://github.com/maxgerhardt/OpenWeatherOneCall/archive/refs/heads/master.zip
(or if you have git
installed, just with the https://github.com/maxgerhardt/OpenWeatherOneCall.git
URL)
Thanks, I saw you already proactively fixed and notified them. Great work!
@ivankravets can you please retrigger the crawler for https://platformio.org/lib/show/7247/OpenWeatherOneCall? The PR for the library.json
fix was merged but no change in the recognized versions.
