VCS + Platformio suddenly stopped working
what in the cornbreed hell ? oO
since yesterday SUDDENLY(!) platformio stopped working.
i used Win7 + VSC + Platformio all the time now and it was great, but now I get this
abstractExtensionService.ts:708 Activating extension ‘platformio.platformio-ide’ failed: EPERM: operation not permitted, read.
(node:3496) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
then there also are some messages like
{message: “Git error”, stdout: “”, stderr: “fatal: e:\PlatformIO-Projects\MKA.pio: ‘e:\PlatformIO-Projects\MKA.pio’ is outside repository↵”, exitCode: 128}
but in my .gitignore the .pio-folder is set to ignore by git
what can I do to get it workung again? I already de-installed VSC and all the code btw. pio folders from AppData and re-installed all again, but I still get the same errors.
Do you have the full output of Help -> Toggle Developer Tools -> Console?
Is E:\ your standard drive or C:?
Hi
C: is my OS-partition, on E: I have all my projects
this is the full output:
aaaaaaaaddd
Can you expand the arrow to the left of the “Activating extension” error?
Also, is the error message correct in saying that E:\Platformio-Projects\MKA\.gitignore is outside a git repository? For that, the MKA folder would have to be a git repo. Consider temporarily moving this .gitignore file out of the folder.
sure, here is the extended message
bbbbbbbbbbbbbbbb
yes the whole MKA-folder is a repo… it is the root of my MKA-project.
And what’s the message underneath the expanded message with “[Extension Host] %Object”?
Can you open a command window (Windows+R, cmd.exe) and do:
E:
cd E:\Platformio-Projects\MKA\
git status
to verify that this is indeed a git folder?
this is the git-message
/C:/Users/adminator/…desktop.main.js:287 [Extension Host]%
Object
exitCode: 128
stderr: “fatal: e:\PlatformIO-Projects\MKA.gitignore: ‘e:\PlatformIO-Projects\MKA.gitignore’ is outside repository↵”
stdout: “”
proto: Object
yes I just done it, my branch ‘origin/master’ is up to date ^^
Hm… Temporarily moving the subcontents of E:\Platformio-Projects\ somewhere else so that that folder is now empty doesn’t make a difference, too?
no when I open a new folder, this “abstractExtensionService.ts:708 Activating extension ‘platformio.platformio-ide’ failed: EPERM: operation not permitted, read.” error appears also.
Well if the E:\Platformio-Projects\ has normal read / write permissions, then I’m genuinely out ideas. Maybe @ivankravets can debug this.
I run Win7 and this happens also when I open a new VSC-window, sooo… :confused:
I really don’t know what to do anymore… I tried to purge all vsc-files/extensions multiple times now from my system, cleared the registry, etc.
but even if I make a brand new install of vsc and then install platformio-ide, this error occurs -.-
[2020-10-14 00:05:31.926] [exthost] [error] Error: EPERM: operation not permitted, read
at Object.readSync (fs.js:506:3)
at tryReadSync (fs.js:331:20)
at Object.readFileSync (fs.js:360:19)
at Object.fs.readFileSync (electron/js2c/asar.js:542:40)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1050:22)
at Module.load (internal/modules/cjs/loader.js:862:32)
at Module._load (internal/modules/cjs/loader.js:774:14)
at Function.Module._load (electron/js2c/asar.js:769:28)
at Function.t._load (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:1057:776)
at Function.i._load (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:1027:486)
at Function.n._load (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:1023:767)
at Module.require (internal/modules/cjs/loader.js:899:19)
at r (e:\Developement\Microsoft VS Code\resources\app\out\vs\loader.js:17:346)
at Object. (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\node_modules\request\index.js:18:15)
at Module.i._compile (e:\Developement\Microsoft VS Code\resources\app\out\vs\loader.js:17:571)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1051:10)
at c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\node_modules\platformio-node-helpers\dist\index.js:1:145
at Object. (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\node_modules\platformio-node-helpers\dist\index.js:1:926)
at Object. (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\dist\extension.js:1:1063)
at o (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\dist\extension.js:1:186)
at Object. (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\dist\extension.js:1:1668)
at c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\dist\extension.js:1:985
at Object. (c:\Users\adminator.vscode\extensions\platformio.platformio-ide-2.1.0\dist\extension.js:1:994)
at require (internal/modules/cjs/helpers.js:74:18)
at Function.s [as __$__nodeRequire] (e:\Developement\Microsoft VS Code\resources\app\out\vs\loader.js:34:963)
at p._loadCommonJSModule (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:1028:771)
at p._doActivateExtension (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:925:742)
at p._activateExtension (e:\Developement\Microsoft VS Code\resources\app\out\vs\workbench\services\extensions\node\extensionHostProcess.js:924:822)
at processTicksAndRejections (internal/process/task_queues.js:94:5)
I have seen a other error in the console (shift+ö)
[14.10.2020, 10:38:48] Die Konfiguration mit compilerPath “C:/Users/adminator/.platformio/packages/toolchain-gccarmnoneeabi/bin/arm-none-eabi-gcc.exe” kann nicht aufgelöst werden.
maybe this helps
Sorry, I don’t have any ideas :frowning:
that means i have to move a ton of stuff and own-libs now back to arduinoIDE :frowning: …that will be a odysee :confused:
why is there no standalone-platformio? -.-
You can always use it from the CLI, was always possible. PlatformIO Core (CLI) — PlatformIO latest documentation
Also a ton of other IDEs are available. See Cloud & Desktop IDEs — PlatformIO latest documentation
Other than a really-really clean re-install of Windows or usage of a VM with Linux I have no other idea for your particular configuration problem.
Does it work from CLI as @maxgerhardt recommends in VCS + Platformio suddenly stopped working - #15 by maxgerhardt ?
No I cant even install the core -.-
I have Python 3.7.4 installed… i download the get-platformio.py and do
python get-platformio.py --help
but i get
  File "get-platformio.py", line 68, in <module>
    main()
  File "get-platformio.py", line 60, in main
    bootstrap()
  File "get-platformio.py", line 44, in bootstrap
    import pioinstaller.__main__
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 668, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\pioinstaller\__main__.py", line 22, in <module>
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\pioinstaller\core.py", line 25, in <module>
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\pioinstaller\home.py", line 19, in <module>
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\requests\__init__.py", line 120, in <module>
sts\utils.py", line 27, in <module>
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\requests\_internal_utils.py", line 11, in <module>
  File "C:\pio_py\.piocore-installer-g_236s0l\tmp3vys3_3y\pioinstaller.zip\requests\compat.py", line 61, in <module>
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 724, in exec_module
  File "<frozen importlib._bootstrap_external>", line 859, in get_code
  File "<frozen importlib._bootstrap_external>", line 917, in get_data
OSError: [Errno 9] Bad file descriptor
I’ve edited your post to use preformatted text instead of blockquote and repaired the forced newlines as good as I could. All formatting expect preformatted text treats angular brackets as HTML tags and basically swallows them.
Sorry, something going wrong with your machine. Please check the permissions. Also, please destroy from system software that damage your machine: dr.web, kasperskyi antivirus, avast, etc.
