My code compiles on one machine but not on the other
Here is the compile error
Processing adafruit_feather_m0 (platform: atmelsam@3.9.0; board: adafruit_feather_m0; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/adafruit_feather_m0.html
PLATFORM: Atmel SAM (3.9.0) > Adafruit Feather M0
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
- framework-arduinosam 4.4.191002
Converting code.ino
ValueError: Invalid simple block '9d5f56fba1':
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/builder/main.py", line 169:
File "/Users/****/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 597:
File "/Users/****/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 286:
File "/Users/****/.platformio/platforms/atmelsam/builder/main.py", line 120:
File "/Users/****/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 219:
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/builder/tools/platformio.py", line 62:
env.ProcessProjectDeps()
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/builder/tools/platformio.py", line 135:
project_lib_builder = env.ConfigureProjectLibBuilder()
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/builder/tools/piolib.py", line 1047:
project.install_dependencies()
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/builder/tools/piolib.py", line 871:
if lm.get_package(spec):
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/manager/base.py", line 227:
spec = self.ensure_spec(spec)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/manager/base.py", line 100:
return spec if isinstance(spec, PackageSpec) else PackageSpec(spec)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/meta.py", line 118:
self._parse(raw)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/meta.py", line 220:
raw = parser(raw)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/meta.py", line 237:
self.requirements = tokens[1].strip()
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/platformio/package/meta.py", line 161:
else semantic_version.SimpleSpec(str(value))
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/semantic_version/base.py", line 618:
self.clause = self._parse_to_clause(expression)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/semantic_version/base.py", line 1014:
return cls.Parser.parse(expression)
File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/semantic_version/base.py", line 1034:
raise ValueError("Invalid simple block %r" % block)
============================================================= [FAILED] Took 0.67 seconds =============================================================
The terminal process "platformio 'run'" terminated with exit code: 1.
