Even for mbed-os that’s a bit much (16 minutes). PIO compiles the entirety of the framework there (if not given .mbedignore files). But still, that should be like 5 min max and not 16. For me on Windows, I had problems with Windows Defender interfering and heavily slowing down the process (Hang creating new projects. Hang using pio install - #2 by maxgerhardt), maybe that is also the case here?
Per NuMaker-PFM-NANO130 | Mbed that board has NANO130KE3BN ARM-Cortex M0+ MCU. PlatformIO doesn’t have any support for Nuvoton MCUs at this point, only one feature requets for another Nuvoton board was filed a year ago. So, you should also open an issue there for a feature request for that board.
If you have the time, you can test a self-made integration: Create any new project, e.g. for the Nucleo F103RB and the mbedos framework. Create a new folder boards in that project, and therein the file numaker_pfm_nano130.json. Fill it with the content
"build": {
"core": "stm32",
"cpu": "cortex-m0",
"extra_flags": "-Dnano130ke3bn",
"f_cpu": "42000000L",
"mcu": "nano130ke3bn",
"product_line": "STM32F103xB",
"variant": "NUMAKER_PFM_NANO130",
"mbed_variant": "NUMAKER_PFM_NANO130"
"debug": {
"default_tools": [
"jlink_device": "NANO130KE3BN",
"onboard_tools": [
"openocd_target": "numicro",
"svd_path": "STM32F103xx.svd"
"frameworks": [
"mbed"
"name": "NuMaker-PFM-NANO130",
"upload": {
"maximum_ram_size": 16384,
"maximum_size": 131072,
"protocol": "mbed",
"protocols": [
"jlink",
"cmsis-dap",
"stlink",
"blackmagic",
"mbed"
"url": "https://os.mbed.com/platforms/NUMAKER-PFM-NANO130/",
"vendor": "Nuvoton"
then change the platformio.ini to
[env:numaker_pfm_nano130]
platform = ststm32
board = numaker_pfm_nano130
framework = mbed
And as src\main.cpp
#include <mbed.h>
int main() {
// available pins see https://github.com/ARMmbed/mbed-os/blob/mbed-os-6.9.0/targets/TARGET_NUVOTON/TARGET_NANO100/PinNames.h
DigitalOut led(LED_RED);
while(1) {
led = 0;
ThisThread::sleep_for(500);
led = 1;
compilation should give
RAM: [===== ] 45.7% (used 7489 bytes from 16384 bytes)
Flash: [== ] 21.8% (used 28552 bytes from 131072 bytes)
=================== [SUCCESS] Took 9.68 seconds ===================
and you can try uploading the firmware normally via the upload button, which should use the USB storage device programming method.
