Hi there, I was wondering if there is a way to force the platformio to simply use the pre-existing local offline version of the ‘ststm32’ platform and ‘framework-mbed’ framework already installed on my machine by platformio (at an earlier date) . Instead of doing a version check and updating the platform/framework first before starting the build process.
In general updating everything first is a good idea but sometimes I prefer to use a specific ‘older’ version of the platform/framework
Thank you
We have an issue #479 where you will be able “to fix the specific version” of a development platform.
Temporary solution, please edit ~/.platformio/appstate.json
and set installed_packages > framework-mbed > version
to 999 (max). In this case, pio
will not update your framework.
I am trying to troubleshoot a ssl connection by adding DEBUGV statements to a .cpp file. This file gets overwritten whenever i build. I tried
“installed_packages”: {“tool-scons”: {“version”: 999, “time”: 1466701971}, “toolchain-xtensa”: {“version”: 999, “time”: 1466701961}, “tool-esptool”: {“version”: 999, “time”: 1466701962}, “tool-mkspiffs”: {“version”: 1, “time”: 1466710556}, “framework-arduinoespressif”: {“version”: 999, “time”: 1467213313}, “ldscripts”: {“version”: 999, “time”: 1467213314}
However, the *.cpp files still are overwritten before they are used. Any suggestions?
Hi @kbrandt!
Please don’t modify files from environment directories .pioenvs
they are temporary and may be overwritten after each build. Packages with source files are located in PlatformIO home directory:
/home/user/.platformio/packages
(Unix)
C:\Users\user\.platformio\packages
(Windows)
Thank you @valeros .this is the information that i needed!
