Hey everyone, I tried to build a esp-idf and arduino mixed project for the ESP32 on PlatformIO and I found out that the default ESP IDF version that is used to build it is the ESP IDF 3.4. Is there a way that I can build my project the with ESP-IDF version 4.3 and above? Thanks for the help.
Regards,
Ameer
Completely outdated. Don’t trust old posts and always check the current state.
If you just build the built-in example project, you will see for yourself that you get
>pio run
Processing esp32dev (board: esp32dev; platform: espressif32; framework: arduino, espidf)
PLATFORM: Espressif 32 (5.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- framework-espidf @ 3.40402.0 (4.4.2)
- tool-cmake @ 3.16.4
ESP-IDF 4.4.2 and Arduino-ESP32 2.0.5 in the latest stable platform-espressif32 version, no modifications needed.
