I’m developing for the Lilygo EPD47 board and while their original repository is not supporting PlatformIO directly, it was easy enough for me to fork it and add a library.json
file that I could send a Pull Request later on:
One thing, though, is that the original content provides board definitions in the platformio/boards folder.
I have copied this folder to my own project and used the following item in the [platformio]
section:
boards_dir = boards
However, I’m wondering if I could avoid copying the folder from the above dependency and use it directly. Here is how I declared the dependency:
lib_deps = https://github.com/obones/LilyGo-EPD47.git#platformio_library
Can it be possible to specify a board from the .pio\libdeps\t5-4_7-plus\LilyGoEPD47\platformio\boards
folder directly?
