I have this platform.ini:
[platformio]
default_envs =
mega2560
esp32
esp8266
native
[env:esp32]
board = node32s
framework = espidf
[env:mega2560]
board = megaatmega2560
[env:native]
platform = native
[env:esp8266]
board = esp01_1m
platform = espressif8266
The trouble is I need to use a different SD library for the mega2560 and for the esp8266**
**failing that i’d just forgo the arduino framework on the ESP8266 altogether but i can’t get the espressif stuff to work with C++ code, only with C code. That’s an alternative (and preferred) solution but I’ve had no luck
So as far as using two different libraries with the same name, but for different builds, how do I do that without modifying the code for the libraries?
