All the time i connect a board STM32F103C8 Generic to usb I have this message:
USB DEVICE NOT DETECTED DEVICE DESCRIPTOR NOT BRECOGNIZED
I have replaced cable, ports, board, PC with no result. The soft is two line just to test
Serial.begin(9600);
Serial.println("Hello, STM32!");
delay(100);
void loop(){
Serial.println("Looping...");
delay(100);
Serial.println("Looping 2 ");
delay(500);
[env:genericSTM32F103C8]
platform = ststm32
board = genericSTM32F103C8
upload_protocol = stlink
debug_tool = stlink
monitor_speed = 9600
It is some time I am using these board but up to now I was not in the need to use serial monitor. For sure is a problem of USB drivers for Win11, STlink is working with no problem.
You’re not activating the USB stack. Serial will go out via UART.
Please follow the documentation
platform = ststm32
debug_tool = stlink
-DPIO_FRAMEWORK_ARDUINO_ENABLE_CDC
At first thank. Ok the problem seem to be solved but it comes out a conflict with “Wire”, this is my feeling.
#include <Wire.h>
int16_t gyro_x, gyro_y, gyro_z;
Serial.begin(9600);
Wire.setClock(400000); // Set I2C frequency to 400kHz
Wire.begin();
delay(250);
Wire.beginTransmission(0x68); // I2C address of MPU6050
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // Set to zero (wakes up the MPU-6050
Wire.endTransmission(true);
Wire.write(0x43); // Starting register for Gyro Readings
Wire.endTransmission();
Wire.requestFrom(0x68, 6, true); // Request 6 bytes from MPU6050
gyro_x = Wire.read() << 8 | Wire.read();
gyro_y = Wire.read() << 8 | Wire.read();
gyro_z = Wire.read() << 8 | Wire.read();
Serial.print("Gyro X= ");
Serial.print(gyro_x);
Serial.print(" Gyro Y= ");
Serial.print(gyro_y);
Serial.print(" Gyro Z= ");
Serial.println(gyro_z);
delay(250);
platform = ststm32
debug_tool = stlink
build_flags = -D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
With this is not working t
What? The USB serial does not interfere with the I2C.
Your code compiles fine, if you want to get rid of the warning, use
Wire.requestFrom((uint8_t) 0x68, (size_t) 6, true); // Request 6 bytes from MPU6050
instead of
The default I2C pins are SDA = PB7 and SCL = PB6.
USB D+ and D- are on PA12 and PA11.
If you are unsure whether the I2C device is detected at all, run the I2C Scanner sketch.
thank solved
I got of rid of warnings, very good, but the bug hunging someware the cpu was
Wire,begin();
instead of
Wire.begin(); Wire.setClock(400000);
