When using the PlatformIO: Upload button I revive this from the terminal but nothing is flashed to the board.
Executing task in folder esp32 test: C:\Users\cloug.platformio\penv\Scripts\platformio.exe run --target upload
The screen cannot be set to the number of lines and columns specified.
=================================================================================================== [SUCCESS] Took 4.04 seconds ===================================================================================================
The serial monitor works fine as I can upload upload with the Arudino IDE and connect with the PlatformIO serial monitor to see serial communication.
Uploading to an Arduino Uno works flawlessly.
Any help would be much appreciated!
