Uploading sketch using JTAG interface on ESP-PROG errors
If you can create a setup that is reproducible for Ivan (see Task error reappearing after update to VSCode 1.47), he is likely going to take care of it.
If I’m not mistaken, the project can start without tasks.json. But once you use the debugger, it needs to be created.
Do I correctly understand your situation: debugging usually works but is a pain to use due to the error messages? Or is debugging broken?
