I am not sure I can be more specific because there are no error messages or other indications of what is wrong.
My script:
#include "Arduino.h"
// Motor control pins
#define LEFT_ENABLE_PIN 5
#define RIGHT_ENABLE_PIN 6
#define IN1_PIN 7
#define IN2_PIN 8
#define IN3_PIN 9
#define IN4_PIN 11
#define ONBOARD_LED_PIN 13
#define ONBOARD_LED_BLINK_RATE_MS 500
#define BLUETOOTH_DELAY_SEC 5
// Speed of the robot in feet/second
#define SPEED_RATE_FORWARD 2.166 // Feet/Second
#define SPEED_RATE_REVERSE 2.10 // Feet/Second
// Minimum and maximum speeds the car is allowed to go
#define SPEED_MIN 110
#define SPEED_MAX 245
// Starting speed and adjustment settings
#define SPEED_LEFT SPEED_MIN
#define SPEED_LEFT_ADJUST 0
#define TURN_RATE_LEFT 289.0 // Degrees/Second
#define TURN_RATE_LEFT_ADJUST 0.0
#define SPEED_RIGHT SPEED_MIN
#define SPEED_RIGHT_ADJUST 0.0
#define TURN_RATE_RIGHT 289.0 // Degrees/Second
#define TURN_RATE_RIGHT_ADJUST 0.0
#define TURN_INCREMENT_DEG 15
// Trackers for the current speed of each side
unsigned int leftSpeedCurrent = SPEED_MIN;
unsigned int rightSpeedCurrent = SPEED_MIN;
unsigned int currentSpeed = SPEED_MIN;
int speedIncrement = TURN_INCREMENT_DEG;
Utility functions
void blinkLED(uint8_t ledPin, uint16_t rateMS) {
digitalWrite(ledPin, HIGH);
delay(rateMS);
digitalWrite(ledPin, LOW);
delay(rateMS);
Robot functions
void setSpeed(unsigned int leftSpeed, unsigned int rightSpeed) {
enableMotors();
if (leftSpeed < SPEED_MIN or leftSpeed + SPEED_LEFT_ADJUST > SPEED_MAX or
rightSpeed < SPEED_MIN or rightSpeed + SPEED_RIGHT_ADJUST > SPEED_MAX) {
// Either the left speed or right speed, or both, are out of range
while(true) {
blinkLED(ONBOARD_LED_PIN, ONBOARD_LED_BLINK_RATE_MS);
} else {
// Set the speeds
analogWrite(LEFT_ENABLE_PIN, leftSpeed + SPEED_LEFT_ADJUST);
leftSpeedCurrent = leftSpeed;
analogWrite(RIGHT_ENABLE_PIN, rightSpeed + SPEED_RIGHT_ADJUST);
rightSpeedCurrent = rightSpeed;
void disableMotors(void) {
digitalWrite(LEFT_ENABLE_PIN, LOW);
digitalWrite(RIGHT_ENABLE_PIN, LOW);
void enableMotors(void) {
digitalWrite(LEFT_ENABLE_PIN, HIGH);
digitalWrite(RIGHT_ENABLE_PIN, HIGH);
void brakeFull(void) {
disableMotors();
//analogWrite(LEFT_ENABLE_PIN, 100);
//analogWrite(RIGHT_ENABLE_PIN, 100);
digitalWrite(IN1_PIN, LOW);
digitalWrite(IN2_PIN, LOW);
digitalWrite(IN3_PIN, LOW);
digitalWrite(IN4_PIN, LOW);
void forward(float distance) {
uint16_t runTimeMS;
enableMotors();
digitalWrite(IN1_PIN, HIGH);
digitalWrite(IN4_PIN, HIGH);
runTimeMS = (int) ((distance / SPEED_RATE_FORWARD) * 1000.0);
delay(runTimeMS);
brakeFull();
void reverse(float distance) {
uint16_t runTimeMS;
enableMotors();
digitalWrite(IN2_PIN, HIGH);
digitalWrite(IN3_PIN, HIGH);
runTimeMS = (int) ((distance / SPEED_RATE_REVERSE) * 1000.0);
delay(runTimeMS);
brakeFull();
void turnLeftRelative(uint16_t turnDegrees) {
uint16_t runTimeMS;
enableMotors();
runTimeMS = (int) ((turnDegrees / (TURN_RATE_LEFT + TURN_RATE_LEFT_ADJUST)) * 1000.0);
//runTimeMS = 311;
delay(runTimeMS);
brakeFull();
void turnRightRelative(uint16_t turnDegrees) {
uint16_t runTimeMS;
enableMotors();
runTimeMS = (int) ((turnDegrees / (TURN_RATE_RIGHT + TURN_RATE_RIGHT_ADJUST)) * 1000.0);
delay(runTimeMS);
brakeFull();
Calibration functions
void calibrateForward() {
digitalWrite(IN1_PIN,HIGH);
digitalWrite(IN2_PIN,LOW);
digitalWrite(IN3_PIN,LOW);
digitalWrite(IN4_PIN,HIGH);
delay(5000);
brakeFull();
void calibrateReverse() {
digitalWrite(IN1_PIN,LOW);
digitalWrite(IN2_PIN,HIGH);
digitalWrite(IN3_PIN,HIGH);
digitalWrite(IN4_PIN,LOW);
delay(5000);
brakeFull();
void calibrateRight() {
delay(5000);
brakeFull();
void calibrateLeft() {
delay(5000);
brakeFull();
void setup(void) {
Serial.begin(15200);
// Setup all the pins
pinMode(LEFT_ENABLE_PIN, OUTPUT);
pinMode(RIGHT_ENABLE_PIN, OUTPUT);
pinMode(IN1_PIN, OUTPUT);
pinMode(IN2_PIN, OUTPUT);
pinMode(IN3_PIN, OUTPUT);
pinMode(IN4_PIN, OUTPUT);
// Allow Bluetooth time to connect
Serial.println("Waiting for Bluetooth to connect");
for (uint8_t i = 0; i < BLUETOOTH_DELAY_SEC * 2; i++) {
// Enable the motors
Serial.println("Enabling motors.");
enableMotors();
// Make sure the motors are stopped
Serial.println("Stopping all motors");
brakeFull();
// Set initial motor speeds
Serial.println("Setting initial motor speeds");
setSpeed(SPEED_LEFT + SPEED_LEFT_ADJUST, SPEED_RIGHT + SPEED_RIGHT_ADJUST);
/* For Robot Calibration ONLY */
//setSpeed(255, 255);
//calibrateForward();
//calibrateReverse();
//calibrateRight();
//calibrateLeft();
analogWrite(LEFT_ENABLE_PIN, 255);
analogWrite(RIGHT_ENABLE_PIN, 255);
turnLeftRelative(90);
void loop(void) {
char command;
if (Serial.available()) {
// Handle commands from remote
command = Serial.read();
// Convert lower to upper case for commands
if (command >= 97 and command <= 122) {
command -= 32;
switch(command) {
case 'F':
forward(1.0);
break;
case 'B':
reverse(1.0);
break;
case 'R':
turnRightRelative(TURN_INCREMENT_DEG);
break;
case 'L':
turnLeftRelative(TURN_INCREMENT_DEG);
break;
} else {
// Do autonomous stuff
setSpeed(SPEED_MIN, SPEED_MIN);
while(true) {
// Change speed ramping direction if neccessary
if (speedIncrement >= 0) {
if (currentSpeed <= 250) {
} else if (currentSpeed >= 250) {
speedIncrement = -30;
} else {
if (currentSpeed >= SPEED_MIN) {
} else if (currentSpeed <= SPEED_MIN) {
speedIncrement = 30;
leftSpeedCurrent += speedIncrement;
rightSpeedCurrent += speedIncrement;
currentSpeed += speedIncrement;
setSpeed(leftSpeedCurrent, rightSpeedCurrent);
delay(1000);
My platform.ini:
[env:uno]
board = uno
upload_port = /dev/ttyACM1
upload_speed = 115200
8-Dale
