In my project with a nano_every, platformio complains when I try to upload to the still unplugged device with the error
avrdude: jtagmkII_getsync(): sign-on command: status -1
The program hangs when I try again with the device plugged in, but only when I use the Upload button at the bottom of the window, and it produces the above error on and on. I have to restart Platformio.
BUT: Using the line “Upload and Monitot” in the lefthand column uploads without problems.
Not a big thing, but is that a bug or am I doing something wrong?
If the upload program avrdude hangs infinitely in such situations without exiting, it’s a bug in their code. You should check if it still occurs when you use the latest AVRdude 8.1 version in such situations: https://github.com/avrdudes/avrdude
PlatformIO can print you the exact upload command via project tasks → Advanced → Verbose Upload, which you can then reuse while targeting the new binary and config files, to check if it occurrs.
The avrdude-version in the tool-avrdude-megaavr-folder is from 2019, the one in the tool-avrdude-Folder is from 2023.
can I replace the old one in megaavr-folder?
Upload-problem:
I wonder why the upload runs well when I use the ‘Upload and Monitor’ item in the Project Task menu, but not when I use the upload-icon at the bottom of the window.
