Upload reports that it's successful but board isn't running application
No the graph says 16Mb with is 16Mega bit so 16/8 = 2 Megabyte
Dangit I can’t believe I missed that! Very silly.
Anyways I did notice once last thing. When it’s programming the board during debug I noticed that there’s two errors that show up (see below). I’m not sure if I should pay attention to these or not since it eventually continues on and says it programmed successfully …
Errors are:
No symbols for FreeRTOS and Too large number of threads 1693293521! (I promise I don’t have 1693293521 threads in my code)
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : tcl server disabled
Info : telnet server disabled
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : accepting 'gdb' connection from pipe
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x40009409 (active) APP_CPU: PC=0x00000000
Info : Target halted. PRO_CPU: PC=0x400916EE (active) APP_CPU: PC=0x00000000
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 121 KB
Info : Flash mapping 1: 0x30018 -> 0x400d0018, 505 KB
Info : Auto-detected flash size 2048 KB
Info : Using flash size 2048 KB
Info : Using flash size 508 KB
Info : Using flash size 124 KB
0x40009409 in ?? ()
Error: Too large number of threads 1693293521!
