Hi there, I have a customized usb bootloader for my blue pill. I’m using stm32cube framework for my code. I can successfully upload my code using dfu-util with a command like
dfu-util -a 0 -s 0x08002000 -D firmware.bin
I also recognize that PlatformIO support dfu-util but it seems it only works for arduino framework which requires maple core. So is it possible to upload my code thru dfu-util on PIO? Thanks all!
Per platform logic, setting upload_protocol = dfu
will invoke dfu-util
except for all microcontrollers starting with stm32f103
, there it is remapped to maple_upload
What’s the exact platformio.ini
Thanks for your reply. So far I haven’t had much configuration. Pretty simple I believe.
[env:genericSTM32F103C8]
platform = ststm32
board = genericSTM32F103C8
framework = stm32cube
upload_protocol =
stlink
; dfu
; upload_flags =
; -c set CPUTAPID 0x2ba01477 ; override default CPU ID for the clone
lib_extra_dirs = ; add a local folder where one or more libraries can be found
${PROJECT_DIR}\3rd-party lib
board_build.ldscript = ; override default LD script
STM32F103C8_FLASH.ld
board_upload.offset_address = 0x2000 ; change the base address of the code for DFU mode
; build_flags =
; -DDFU_MODE
; -UVECT_TAB_OFFSET
; -DUSER_VECT_TAB_ADDRESS
; -DVECT_TAB_OFFSET=0x2000 ; override default vector tale to support ISR table for DFU mode
Open the file C:\Users\<user>\.platformio\platforms\ststm32\builder\main.py
locally at line 228
and change it to
elif board.get("build.mcu").startswith("stm32f103") and False:
to prevent PlatformIO from remapping it to maple_upload
What does a “Advanced → Verbose Upload” show then as the final upload command?
Hi, it looks like this. I’m not with my device so will upload results when using Verbose Upload later on!
