I’ve been trying to install this and get this error on my first build. I’ve updated everything else (Atom packages, platformio core, platform packaches and libraries. My platformio.ini is:
platform = espressif32_stage
The error is:
[03/01/17 17:48:47] Processing esp32dev (platform: espressif32_stage, board: esp32dev, framework: ar
duino)
PackageManager: Installing framework-arduinoespressif32
git version 2.12.0.windows.1
Cloning into ‘C:\Users\steve.platformio\packages\installing-yh6zus-package’…
framework-arduinoespressif32 @ 0.0.0 has been successfully installed!
Verbose mode can be enabled via -v, --verbose
option
TypeError: object of type ‘NoneType’ has no len():
File “C:\Users\steve.atom\packages\platformio-ide\penv\lib\site-packages\platformio\builder\main.py
“, line 142:
env.SConscript(”$BUILD_SCRIPT”)
File “C:\Users\steve.platformio\packages\tool-scons\script..\engine\SCons\Script\SConscript.py”, l
ine 541:
ine 250:
exec file in call_stack[-1].globals
File “C:\Users\steve.platformio\platforms\espressif32_stage\builder\main.py”, line 138:
File “C:\Users\steve.platformio\packages\tool-scons\script..\engine\SCons\Environment.py”, line 22
4:
File “C:\Users\steve.atom\packages\platformio-ide\penv\lib\site-packages\platformio\builder\tools\p
latformio.py”, line 56:
env.BuildFrameworks(env.get(“PIOFRAMEWORK”))
4:
latformio.py”, line 258:
SConscript(env.GetFrameworkScript(f))
ine 604:
return method(*args, **kw)
ine 541:
ine 250:
File “C:\Users\steve.platformio\platforms\espressif32_stage\builder\frameworks\arduino.py”, line 30
“framework-arduinoespressif32”), “tools”, “platformio-build.py”))
File “c:\users\steve.atom\packages\platformio-ide\penv\lib\ntpath.py”, line 65:
result_drive, result_path = splitdrive(path)
File “c:\users\steve.atom\packages\platformio-ide\penv\lib\ntpath.py”, line 115:
if len(p) > 1:
[ERROR] Took 9.14 seconds
