PlatformIO Community
Unit testing on local/native with dependency on mbed.h
So I can run unit testing on local machine using
[env:local]
platform = native
test_ignore = test_device
Which means that I cannot use #include <mbed.h> in any of the libraries that are being tested, otherwise `fatal error: mbed.h: No such file or directory’.
And I cannot use framework = mbed on my local configuration because there are no boards supported by PIO on this platform.
So how can I include the external library mbed on my native platform which allows me to compile and run tests ?
Obviously the goal is not to test the mbed library on my local PC, but I do need to test libraries which are designed to run with mbed.
You can use build_flags for “native” and configure extra CPPPATHs
[env:local]
platform = native
  -I$PROJECT_CORE_DIR/framework-mbed
