I am a little confused by what I just experienced.
I had a header that had some definitions inside of it wrapped in a preprocessor conditional that I thought would stop it from being included multiple times.
Long story short, this is what I am talking about:
#ifndef GEN3_SX1509_REGISTERS
#define GEN3_SX1509_REGISTERS
byte REG_I_ON[16] = {REG_I_ON_0, REG_I_ON_1, REG_I_ON_2, REG_I_ON_3,
REG_I_ON_4, REG_I_ON_5, REG_I_ON_6, REG_I_ON_7,
REG_I_ON_8, REG_I_ON_9, REG_I_ON_10, REG_I_ON_11,
REG_I_ON_12, REG_I_ON_13, REG_I_ON_14, REG_I_ON_15};
byte REG_T_ON[16] = {REG_T_ON_0, REG_T_ON_1, REG_T_ON_2, REG_T_ON_3,
REG_T_ON_4, REG_T_ON_5, REG_T_ON_6, REG_T_ON_7,
REG_T_ON_8, REG_T_ON_9, REG_T_ON_10, REG_T_ON_11,
REG_T_ON_12, REG_T_ON_13, REG_T_ON_14, REG_T_ON_15};
byte REG_OFF[16] = {REG_OFF_0, REG_OFF_1, REG_OFF_2, REG_OFF_3,
REG_OFF_4, REG_OFF_5, REG_OFF_6, REG_OFF_7,
REG_OFF_8, REG_OFF_9, REG_OFF_10, REG_OFF_11,
REG_OFF_12, REG_OFF_13, REG_OFF_14, REG_OFF_15};
byte REG_T_RISE[16] = {0xFF, 0xFF, 0xFF, 0xFF,
REG_T_RISE_4, REG_T_RISE_5, REG_T_RISE_6, REG_T_RISE_7,
REG_T_RISE_12, REG_T_RISE_13, REG_T_RISE_14, REG_T_RISE_15};
byte REG_T_FALL[16] = {0xFF, 0xFF, 0xFF, 0xFF,
REG_T_FALL_4, REG_T_FALL_5, REG_T_FALL_6, REG_T_FALL_7,
REG_T_FALL_12, REG_T_FALL_13, REG_T_FALL_14, REG_T_FALL_15};
Those definitions were causing a bunch of “multiple definition” errors… but how?
I just moved them to the associated .cpp file, and replaced them with extern declarations, and that fixed the issue
extern byte REG_I_ON[16];
extern byte REG_T_ON[16];
extern byte REG_OFF[16];
extern byte REG_T_RISE[16];
extern byte REG_T_FALL[16];
I was hoping someone had an explanation as to why the preprocessor wasn’t stopping the original code from being executed multiple times.
