When I try to compile my code I keep getting this error
C:\Users\maxim\AppData\Local\Temp\cczhNVX5.ltrans0.ltrans.o: In function `TM1637Display::stop() [clone .constprop.33]':
<artificial>:(.text+0x30a): undefined reference to `hdtelevize'
<artificial>:(.text+0x30c): undefined reference to `hdtelevize'
C:\Users\maxim\AppData\Local\Temp\cczhNVX5.ltrans0.ltrans.o: In function `TM1637Display::writeByte(unsigned char) [clone .constprop.32]':
<artificial>:(.text+0x362): undefined reference to `hdtelevize'
<artificial>:(.text+0x37a): undefined reference to `hdtelevize'
<artificial>:(.text+0x38a): undefined reference to `hdtelevize'
C:\Users\maxim\AppData\Local\Temp\cczhNVX5.ltrans0.ltrans.o:<artificial>:(.text+0x3a4): more undefined references to `hdtelevize' follow
*** [.pio\build\uno\firmware.elf] Error 1
main.cpp
#include <Arduino.h> // Arduino
#include <Wire.h> // Připojení
#include <ClockShield.h> // Displej
ShieldDisplay tmdisplej(7, 8);
ShieldClock rtchodiny;
void setup()
Serial.begin(9600); // Spuštení sériové komunikace
if (!rtchodiny.begin())
{ // Kontrola připojení hodin
Serial.println("Clock not connected!");
while (true)
if (!rtchodiny.isrunning())
{ // Kontrol spuštění hodin
Serial.println("Clock not running. Starting now...");
tmdisplej.setBrightness(15); // Podsvícení 8-15
tmdisplej.temp();
void loop()
lib/ClockShield/ClockShield.h
#ifndef ClockShield_h
#define ClockShield_h
#include <TM1637Display.h>
#include <RTClib.h>
extern TM1637Display hdtelevize;
extern RTC_DS1307 hodiny;
class ShieldDisplay
public:
ShieldDisplay(uint8_t pinCLK, uint8_t pinDIO);
void setBrightness(uint8_t brightness);
void temp();
class ShieldClock
public:
ShieldClock();
boolean begin();
uint8_t isrunning();
lib/ClockShield/ClockShield.cpp
#include "ClockShield.h"
#include <RTClib.h>
ShieldDisplay::ShieldDisplay(uint8_t pinCLK, uint8_t pinDIO)
hdtelevize = TM1637Display(pinCLK, pinDIO);
void ShieldDisplay::setBrightness(uint8_t brightness)
hdtelevize.setBrightness(brightness);
void ShieldDisplay::temp()
DateTime ted = hodiny.now();
vypis[0] = hdtelevize.encodeDigit(ted.hour() / 10);
vypis[1] = hdtelevize.encodeDigit(ted.hour() % 10);
vypis[2] = hdtelevize.encodeDigit(ted.minute() / 10);
vypis[3] = hdtelevize.encodeDigit(ted.minute() % 10);
if ((millis() % 1000) >= 500)
hdtelevize.setSegments(vypis);
else
vypis[1] = vypis[1] + 128;
ShieldClock::ShieldClock()
hodiny = RTC_DS1307();
boolean ShieldClock::begin()
return hodiny.begin();
uint8_t ShieldClock::isrunning()
return hodiny.isrunning();
lib/TM1637Display/TM1637Display.cpp (not whole)
void TM1637Display::stop()
pinMode(m_pinDIO, OUTPUT);
bitDelay();
pinMode(m_pinClk, INPUT);
bitDelay();
pinMode(m_pinDIO, INPUT);
bitDelay();
bool TM1637Display::writeByte(uint8_t b)
uint8_t data = b;
// 8 Data Bits
for(uint8_t i = 0; i < 8; i++) {
// CLK low
pinMode(m_pinClk, OUTPUT);
bitDelay();
// Set data bit
if (data & 0x01)
else
bitDelay();
// CLK high
bitDelay();
data = data >> 1;
// Wait for acknowledge
// CLK to zero
bitDelay();
// CLK to high
bitDelay();
uint8_t ack = digitalRead(m_pinDIO);
if (ack == 0)
bitDelay();
bitDelay();
return ack;
I know it is kinda long, but I searched for this issue and I could not find any working solution. Thanks for help!
