Why I receive this error?
.pio\build\esp32dev\src\main.cpp.o:(.literal._Z5setupv+0x88): undefined reference to `EEprom_Utility::Istanzia_EEprom(int)’
Here the code:
Here the code:
You’re doing C++ classes very wrong. When you have a header file with
class EEprom_Utility {
public:
bool Istanzia_EEprom(int Dimensione_EEprom);
String Formatta(String Nome_Variabile, String Contenuto_Variabile, byte Lunghezza_Campo, bool Debug);
String Leggi (int _address_Begin, int _address_End, bool Debug);
bool Scrivi(String Nome_Variabile, String Contenuto_Variabile, int Indirizzo_Begin, int Indirizzo_End, bool Debug);
Then the accompanying .cpp
file must not again create a class EEprom_Utility {}
but just include the header file and implement the functions like
#include "Factory.h"
bool EEprom_Utility::Istanzia_EEprom(int Dimensione_EEprom) {
/* implementation */
I took the liberty to correct the mistakes and auto-format the source code (Ctrl+Shift+P → Format Document). See https://drive.google.com/file/d/1U-gW2kaEN5gJ-Rv4XkI31n4GIsTytT6G/view?usp=sharing
For more reading on C++ class programming, please read
Many thanks for help!
I have used a wrong template taken from chatGPT…
One more reason to learn coding for real instead of taking questionable results from a neural network.
Just curious, could you ask chatGPT to fix the issue? Does it provide the correct answer?
If it have create a wrong structure of class (example template) I don’t thing that it will create working code…
