Try to implement ESP32-IDF OTA project, but have very strange linker error:
Linking .pioenvs/node32s/firmware.elf
.pioenvs/node32s/libapp_update.a(esp_ota_ops.o):(.literal.esp_ota_end+0x0): undefined reference to esp_image_basic_verify' .pioenvs/node32s/libapp_update.a(esp_ota_ops.o): In functionesp_ota_end’:
…/.platformio/packages/framework-espidf/components/app_update/esp_ota_ops.c:218: undefined reference to esp_image_basic_verify' .pioenvs/node32s/libapp_update.a(esp_ota_ops.o): In functionesp_ota_set_boot_partition’:
…/.platformio/packages/framework-espidf/components/app_update/esp_ota_ops.c:359: undefined reference to `esp_image_basic_verify’
*** [.pioenvs/node32s/firmware.elf] Error 1
Code seems to be ok, maybe somebody knows how to add necessary libs to linker?
Tried to use this example.
Well… There a some errors in Platformio too.
For example:
error: ‘esp_ota_get_running_partition’ was not declared in this scope
error: ‘esp_ota_get_next_update_partition’ was not declared in this scope
When i tried to find this functions in “esp_ota_ops.h” platformio i did not find anything like that.
Pretty strange to understand that platformio esp-idf differ from original one.
Were you able to get the classycodeoss esp32-ota-https example to run with Platformio? In another post you said you “need to remove “bootloader_support” from ignore_dirs variable in platformio espidf.py.” Can you give more details (location of file or settings)?
