Greetings!
I’m trying to reproduce esp-idf example storage/spiffsgen.
Getting error:
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\spiffsgen_example_main.o:(.literal.compute_alice_txt_md5+0x14): undefined reference to `mbedtls_md5_init'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\spiffsgen_example_main.o:(.literal.compute_alice_txt_md5+0x18): undefined reference to `mbedtls_md5_starts'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\spiffsgen_example_main.o:(.literal.compute_alice_txt_md5+0x1c): undefined reference to `mbedtls_md5_update'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\spiffsgen_example_main.o:(.literal.compute_alice_txt_md5+0x20): undefined reference to `mbedtls_md5_finish'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\spiffsgen_example_main.o: in function `compute_alice_txt_md5':
D:\ESP32\spiffsgen/src/spiffsgen_example_main.c:45: undefined reference to `mbedtls_md5_init'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\ESP32\spiffsgen/src/spiffsgen_example_main.c:46: undefined reference to `mbedtls_md5_starts'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\ESP32\spiffsgen/src/spiffsgen_example_main.c:62: undefined reference to `mbedtls_md5_update'
c:/users/kossn/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/11.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: D:\ESP32\spiffsgen/src/spiffsgen_example_main.c:63: undefined reference to `mbedtls_md5_finish'
In .map file cross reference section I have wrong reference:
mbedtls_internal_sha256_process .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
mbedtls_md5_finish .pio\build\esp32dev\src\spiffsgen_example_main.o
mbedtls_md5_init .pio\build\esp32dev\src\spiffsgen_example_main.o
mbedtls_md5_starts .pio\build\esp32dev\src\spiffsgen_example_main.o
mbedtls_md5_update .pio\build\esp32dev\src\spiffsgen_example_main.o
mbedtls_sha256_clone .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
mbedtls_sha256_finish .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
.pio\build\esp32dev\esp-idf\bootloader_support\libbootloader_support.a(bootloader_sha.o)
mbedtls_sha256_free .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
mbedtls_sha256_init .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
mbedtls_sha256_starts .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
mbedtls_sha256_update .pio\build\esp32dev\esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a(esp_sha256.o)
But, they linked in esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a
build.ninja:
# Link the static library esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a
build esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a: CXX_STATIC_LIBRARY_LINKER__mbedcrypto esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/aes.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/aesni.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/aria.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/asn1parse.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/asn1write.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/base64.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/bignum.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/camellia.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ccm.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/chacha20.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/chachapoly.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/cipher.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/cipher_wrap.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/constant_time.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/cmac.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ctr_drbg.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/des.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/dhm.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ecdh.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ecdsa.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ecjpake.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ecp.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ecp_curves.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/entropy.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/entropy_poll.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/error.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/gcm.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/hkdf.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/hmac_drbg.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/md.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/md5.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/memory_buffer_alloc.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/mps_reader.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/mps_trace.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/nist_kw.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/oid.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/padlock.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pem.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pk.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pk_wrap.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pkcs12.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pkcs5.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pkparse.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/pkwrite.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/platform.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/platform_util.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/poly1305.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_aead.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_cipher.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_client.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_ecp.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_hash.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_mac.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_rsa.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_se.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_slot_management.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_crypto_storage.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/psa_its_file.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ripemd160.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/rsa.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/rsa_alt_helpers.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/sha1.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/sha256.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/sha512.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/ssl_debug_helpers_generated.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/threading.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/timing.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/version.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/version_features.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/esp_hardware.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/esp_mem.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/esp_timing.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/sha/esp_sha.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/aes/esp_aes_xts.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/aes/esp_aes_common.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/aes/block/esp_aes.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/sha/parallel_engine/sha.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/esp_bignum.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/esp32/bignum.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/sha/parallel_engine/esp_sha1.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/sha/parallel_engine/esp_sha256.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/sha/parallel_engine/esp_sha512.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/aes/esp_aes_gcm.c.obj esp-idf/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/__/__/port/md/esp_md.c.obj || esp-idf/mbedtls/mbedtls/library/libmbedx509.a
LANGUAGE_COMPILE_FLAGS = -mlongcalls -Wno-frame-address
OBJECT_DIR = esp-idf\mbedtls\mbedtls\library\CMakeFiles\mbedcrypto.dir
POST_BUILD = cd .
PRE_LINK = cd .
TARGET_COMPILE_PDB = esp-idf\mbedtls\mbedtls\library\CMakeFiles\mbedcrypto.dir\mbedcrypto.pdb
TARGET_FILE = esp-idf\mbedtls\mbedtls\library\libmbedcrypto.a
TARGET_PDB = esp-idf\mbedtls\mbedtls\library\libmbedcrypto.pdb
