I’m very new to PlatformIO IDE (on VS Code) and only discovered it because the MCU manufacturer I’m trying to use, provides a framework for it.
I’m starting with the provided examples from the manufacturer for the specific dev board(s) I have but I’m running into problems loading the compiled code to the device.
Terminal output is as follows:
* Executing task: platformio run --target upload
Processing genericAT32F407VGT7 (platform: arterytekat32; board: genericAT32F407VGT7; framework: at32firmlib)
CONFIGURATION: https://docs.platformio.org/page/boards/arterytekat32/genericAT32F407VGT7.html
PLATFORM: ArteryTek AT32 (1.0.2) > AT32F407VGT7 (96K/224K RAM. 1024K Flash)
HARDWARE: AT32F407VGT7 240MHz, 96KB RAM, 1MB Flash
DEBUG: Current (atlink) External (atlink, atlink_dap_v2, cmsis-dap, jlink, stlink)
- framework-at32firmlib @ 2.0.1
- tool-openocd-at32 @ 0.1100.220911 (11.0)
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 1 compatible libraries
|-- at32f403a_407_board
Checking size .pio/build/genericAT32F407VGT7/firmware.elf
RAM: [ ] 0.1% (used 76 bytes from 98304 bytes)
Flash: [ ] 0.3% (used 2712 bytes from 1048576 bytes)
AVAILABLE: atlink, atlink_dap_v2, cmsis-dap, jlink, stlink
CURRENT: upload_protocol = atlink
Uploading .pio/build/genericAT32F407VGT7/firmware.elf
Open On-Chip Debugger 0.11.0-00006-gbec841d-dirty (2022-09-11-22:29)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
swd
Error: unable to find a matching CMSIS-DAP device
Error: No Valid JTAG Interface Configured.
*** [upload] Error 255
Does anyone have any suggestions on how I might fix this?
Well does that dev board you’re working with have a CMSIS-DAP style debugger on board, physically?
When you open the Windows device manager or lsusb
, do you see any CMSIS-DAP device?
Did you maybe connect a different SWD probe to the target, like an ST-Link?
I’m on Linux, so no Device Manager, I don’t see anything helpful with lsusb. I don’t know for a fact that it has a CMSIS device on board, but it has it listed as an option in the debug options, although AT-Link is listed as the default.
I’m guessing the configuration needs to be changed, but I have no idea where to do that for PIO.
I need you to post the link to your exact dev board, or a closeup photo thereof.
Also, unplug the board. Open a new terminal, execute sudo dmesg -w
, enter your password and then press enter once. Plug the board back in. What new lines did appear in the log?
I’m evaluating two boards AT32-START-407 and AT32-START-437, but starting with the 407 first.
Info for the 407 at:
雅特力科技 Artery :: Usher in a new era of 32-bit microcontrollers Has basic MCU info
https://www.arterychip.com/download/AT-START/AT_START_F407_V1.2_EN.zip Contains PDFs with more detailed info, including photos of the board.
Same for the 437 at:
雅特力科技 Artery :: Usher in a new era of 32-bit microcontrollers and https://www.arterychip.com/download/AT-START/AT_START_F437_V1.1.zip
I’m beginning to think it might be easier to use protocol_command with the custom atlink command, but that would entail setting up a separate non-standard method which I would prefer to avoid.
EDIT: Ooops forgot to say. The sudo dmesg -w
produced nothing new to the screen.
Well then something is wrong, if you have the “AT-START-F407” board, then there’s supposed to be an “AT-LINK EZ” on board, implemented in a separate AT32F304 chip. There are two USB connectors on the board, one USB Micro-B for the AT-LINK EZ (“CN6”) and another USB Micro-B “CN1” that connects to the F407.
- Are you sure you have the USB cable plugged into CN6, not CN1?
- Is R37 and R38 populated on the board?
- Have you made sure that the USB cable has power and data lines? (Charge-only cables exist)
1 Yes
2 Yes
3 hmmm, no idea. Do not even remember where the cable came from. I’ve ordered a new one from Amazon and will let you know Monday/Tuesday when it arrives.
Received the new USB cable today. It appears the old one is indeed power only, as I now get output from the dmesg -W command:
[ 399.166335] hid-generic 0003:2E3C:F000.0006: hiddev98,hidraw4: USB HID v1.00 Device [Artery Technology CMSIS-DAP] on usb-0000:0a:00.1-5/input2
[ 399.306197] cdc_acm 1-5:1.0: ttyACM0: USB ACM device
[ 399.306219] usbcore: registered new interface driver cdc_acm
[ 399.306220] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Loading code to the board now works.
Many thanks for your help.
