In this simple program, I try to catch and handle a dummy exception on the Adafruit ItsyBitsy M0.
I am using Visual Studio Code with PlatformIO.
Visual Studio Code version 1.68.1
PlatformIO Core version 6.1.4
PlatformIO Home version 3.4.3
Below is the platformio.ini
and main.cpp
source file used.
main.cpp
#include <stdexcept> // including only <exception> leaves std::runtime_error undefined
Serial.begin(9600);
while (!Serial) {
delay(100); // wait for the serial port to connect
Serial.println("Start.");
try {
throw std::runtime_error("dummy exception"); // trigger a catch
} catch (const std::exception& e) {
Serial.println(e.what());
Serial.println("End.");
// Do nothing.
platformio.ini
[env:adafruit_itsybitsy_m0]
platform = atmelsam
board = adafruit_itsybitsy_m0
Without the build flag -fexceptions
, the code would not compile:
src\main.cpp: In function 'void setup()':
src\main.cpp:13:51: error: exception handling disabled, use '-fexceptions' to enable
13 | throw std::runtime_error("dummy exception");
After that was added, the code compiled. The file is now:
platformio.ini
platform = atmelsam
-fexceptions
However, the program output did not match my expectation.
Expected output:
Start.
dummy exception
End.
Actual output:
Start.
From that, you can see the exception is not handled, and the program stops without printing the last print statement.
Seeing as I could not find a solution to the problem online. I gave solutions to other boards a try, among others: how to enable exceptions on ESP8266. And added the build unflag -fno-exceptions
The complete platformio.ini file is now:
platformio.ini
platform = atmelsam
-fexceptions
build_unflags =
-fno-exceptions
However, the output remains the same and the problem is not solved.
Other things I have tried is add the build flags -lstdc++
and -lsupc++
. No luck.
Inspired by this issue, added the unbuild flag --specs=nano.specs
, again, no luck.
On the similar board SparkFun Electronics SAMD21 Mini Breakout, that uses the same microcontroller (ATSAMD21G18 32-bit Cortex M0+) , I am able to handle the exception as intended.
main.cpp
#undef max // conflicts with standard library
#undef min // conflicts with standard library
SerialUSB.begin(9600);
while (!SerialUSB) {
SerialUSB.println("Start.");
try {
SerialUSB.println(e.what());
SerialUSB.println("End.");
// Do nothing.
platformio.ini
[env:sparkfun_samd21_mini_usb]
platform = atmelsam
board = sparkfun_samd21_mini_usb
-fexceptions
build_unflags =
-fno-exceptions
--specs=nano.specs
Because it is possible on the SAMD21 Mini Breakout, it leads me to believe it is possible on the ItsyBitsy M0 too.
How can I successfully handle an exception on the Adafruit ItsyBitsy M0?
Thank you in advance.
