I’ve a problem with remote upload, pio monitor command is working and there is a successful connection between host and remote PCs in PlatformIO.
When I run the following command:
platformio.exe remote run --target upload
I got this error:
Uploading firmware remotely
(2, 'CreateProcess', 'The system cannot find the file specified.')
Also, on Remote Development Menu I see only two options, maybe it’s related to issue I reported above
Same with
pio remote run -t upload --force-remote
I got the same result with that command
What’s the platformio.ini? Is the remote computer a regular Windows PC?
It’s a regular Windows PC. Below is just part of the platformio.ini, I can’t paste the whole file because of some private data. It is important that code is built successfully and works when it’s flashed directly on the host machine and device.
[common]
-D DEFAULT_SOLUTION=APP_ID
[env:iiot_application]
platform = https://github.com/platformio/platform-espressif32.git
platform_packages =
framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#2.0.3
toolchain-xtensa-esp32@8.4.0+2021r2-patch3
board_build.partitions = partitions_custom_16MB.csv
board_upload.flash_size = 16MB
board_upload.maximum_size = 16732160
hunamizawa/ESPPerfectTime@^0.3.0
vshymanskyy/StreamDebugger @ ^1.0.1
lewisxhe/PCF8563_Library@^0.0.1
sandeepmistry/LoRa@^0.8.0
-D TINY_GSM_MODEM_SIM7000
monitor_filters = esp32_exception_decoder, time
That’s a weird way of writing platform = espressif32@5.0.0
, which would also give you Arduino-ESP 2.0.3. Is it any different with that?
Same result. I don’t even understand why this could create a problem when compiling process is successful and the local upload/monitor is working.
