Sorry for my English.
Yesterday I compiled the Marlin project for 3D printers several times without worry, but today not possible.
Yesterday every time I modified marlin to suit my printer, I saved the complete folder.
And today none of these backups cant to compile.
The program runs on an MKS SGen_L V2.0 motherboard, with an LPC1769 processor.
I haven’t changed anything since yesterday and it no longer works. last night I had an update, and I do not know if I made any tests after this update, which probably explains my problem.
When I run the compilation, I quickly get yellow and red error lines
I tried to put my folder with marlin, at the root of my hard drive, to have a short path. Without results.
I tried to uninstall, PlatformIO, then Visual Studio Code, to reinstall them, but without result.
Do you have any ideas please?
PlatformIO is in: Core 5.1.0 Home 3.3.3
Visual Studio Code in: 1.53.2
> Executing task in folder Marlin-bugfix-2.0.x: C:\Users\Chris\.platformio\penv\Scripts\pio.exe run < Processing LPC1769 (platform: https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.3.zip; board: nxp_lpc1769; framework: arduino) ------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1769 HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash DEBUG: Current (jlink) On-board (cmsis-dap) External (blackmagic, jlink) PACKAGES: - framework-arduino-lpc176x 0.2.5 - toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1) Converting Marlin.ino LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf LDF Modes: Finder ~ off, Compatibility ~ strict Found 1 compatible libraries Scanning dependencies... Dependency Graph |-- <Servo> 1.0.0 Building in release mode Unable to find destination disk (Autodetect Error) Please select it in platformio.ini using the upload_port keyword (https://docs.platformio.org/en/latest/projectconf/section_env_upload.html) or copy the firmware (.pio/build/LPC1769/firmware.bin) manually to the appropriate disk Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\fast_pwm.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\digipot_mcp4451_I2C_routines.c.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\include\i2c_util.c.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o Compiling .pio\build\LPC1769\src\src\HAL\LPC1768\tft\tft_spi.cpp.o In file included from Marlin\src\HAL\LPC1768\../../core/../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../core/../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\../../core/serial.h:24, from Marlin\src\HAL\LPC1768\DebugMonitor.cpp:25: Marlin\src\HAL\LPC1768\../../core/../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\LPC1768\../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\HAL.cpp:24: Marlin\src\HAL\LPC1768\../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\DebugMonitor.cpp.o] Error 1 In file included from Marlin\src\HAL\LPC1768\../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\HAL_SPI.cpp:51: Marlin\src\HAL\LPC1768\../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL.cpp.o] Error 1 compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\HAL_SPI.cpp.o] Error 1 In file included from Marlin\src\HAL\LPC1768\../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\eeprom_flash.cpp:39: Marlin\src\HAL\LPC1768\../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. In file included from Marlin\src\HAL\LPC1768\../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\eeprom_sdcard.cpp:25: Marlin\src\HAL\LPC1768\../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_flash.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_sdcard.cpp.o] Error 1 In file included from Marlin\src\HAL\LPC1768\../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\eeprom_wired.cpp:24: Marlin\src\HAL\LPC1768\../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. arm-none-eabi-g++: fatal error: cannot execute 'as': CreateProcess: No such file or directory compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\fast_pwm.cpp.o] Error 1 *** [.pio\build\LPC1769\src\src\HAL\LPC1768\eeprom_wired.cpp.o] Error 1 arm-none-eabi-gcc: fatal error: cannot execute 'as': CreateProcess: No such file or directory compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\include\digipot_mcp4451_I2C_routines.c.o] Error 1 arm-none-eabi-gcc: fatal error: cannot execute 'as': CreateProcess: No such file or directory compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\include\i2c_util.c.o] Error 1 In file included from Marlin\src\HAL\LPC1768\tft\../../../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\tft\../../../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\tft\tft_spi.cpp:23: Marlin\src\HAL\LPC1768\tft\../../../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\tft\tft_spi.cpp.o] Error 1 In file included from Marlin\src\HAL\LPC1768\../../sd/../inc/../HAL/HAL.h:26, from Marlin\src\HAL\LPC1768\../../sd/../inc/MarlinConfig.h:30, from Marlin\src\HAL\LPC1768\../../sd/cardreader.h:24, from Marlin\src\HAL\LPC1768\main.cpp:38: Marlin\src\HAL\LPC1768\../../sd/../inc/../HAL/./LPC1768/HAL.h:35:10: fatal error: algorithm: No such file or directory 35 | #include <algorithm> | ^~~~~~~~~~~ compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\main.cpp.o] Error 1 arm-none-eabi-g++: fatal error: cannot execute 'as': CreateProcess: No such file or directory compilation terminated. *** [.pio\build\LPC1769\src\src\HAL\LPC1768\MarlinSerial.cpp.o] Error 1 ============================================================= [FAILED] Took 2.71 seconds ============================================================= Environment Status Duration ------------- -------- ------------ LPC1769 FAILED 00:00:02.714
[EDIT]I just tried with a marlin download from the official site, and compiling keeping the mega2560 and BOARD_RAMPS_14_EFB, it works, but as soon as I put my LPC1769 and BOARD_MKS_SGEN_L_V2 card back, it doesn’t work anymore.
