I am using platformio as IDE for Arduino. I followed this [iurl=https://docs.platformio.org/en/latest/faq.html#platformio-udev-rules]link[/iurl] to run a sketch and it was successfully uploaded in A. Leonardo.
When I started the IDE again, I still have problems uploading the sketch:
Processing leonardo (platform: atmelavr; board: leonardo; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/leonardo.html
PLATFORM: Atmel AVR (3.0.0) > Arduino Leonardo
HARDWARE: ATMEGA32U4 16MHz, 2.50KB RAM, 28KB Flash
- framework-arduino-avr 5.1.0
Found 5 compatible libraries
Linking .pio/build/leonardo/firmware.elf
.pio/build/leonardo/src/main.cpp.o (symbol from plugin): In function `setup':
(.text+0x0): multiple definition of `setup'
.pio/build/leonardo/src/colorReader.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `loop'
*** [.pio/build/leonardo/firmware.elf] Error 1
========================== [FAILED] Took 1.09 seconds ==========================
What might be wrong?
How can I set the board once and for all?
Thank you
