Why doesn’t this work?
void drawLine(uint16_t 1, uint16_t 17, uint16_t 120, uint16_t 17, uint16_t WHITE);
PIO says something has to come between uint16_t and 1. It wants punctuation before a numeric constant.
Hi Joe.
Are you declaring the drawLine()
function, or calling it?
For a declaration:
// Draw a line from (x0,y0) to (x1,y1).
void drawLine(uint16_t x0, uint16_t y0,
uint16_t x1, uint16_t y1,
uint16_t colour);
For a call, it would be:
drawLine(1, 17, 120, 17, WHITE);
Edit: Happy Christmas.
Cheers,
Norm.
Edit by @maxgerhardt: Removed void
in front of the function call for correctness
Would you do the void
also? I’ve never tried doing that with a function call… so don’t know if the compiler would spit the dummy if I did…
Thanks for the edit @maxgerhardt, I’m afraid I forgot to remove the void
as part of a copy/paste!
Happy Christmas.
Cheers,
Norm.
You can do this:
(void) drawLine(1, 17, 120, 17, WHITE);
If the function returns a value that is of no interest, but it’s not necessary.
Cheers,
Norm.
Thank you very much. I didn’t realize we had to declare a line. I thought it was a machine function, not a real library creature.
Bon natale
Hi Joe.
Your question was:
Because it is incorrect C/C++. This looks like a declaration of a function, but with numbers instead of names for the parameters. That is not allowed.
If, on the other hand, it was actually a function call,then you onlyneed the numbers and not the data types – the declaration has already defined those, most likely in a (library?) Header file.
Cheers,
Norm.
