I’m trying to use PlatformIO on an Odroid C2, which is 64-bit ARM. It’s a really snappy setup (4 cores, 2 GB RAM), especially with eMMC as root storage.
The installed toolchain for arm-gcc-embedded appears to be 32-bit. This page helped make them work anyway:
But I’m using some C++11 constructs in my code, which don’t get recognised. Adding build_flags = -std=c++11
got rid of most of the errors. Unfortunately, the compiler appears to be somewhat outdated, and doesn’t accept some construct (using __VA_ARGS__
in a macro), or at least not as it works on x86-64.
The version of gcc I see inside ~/.platformio/packages/toolchain-gccarmnoneeabi/bin/
is:
gcc version 4.8.3 20140228 (release) [ARM/embedded-4_8-branch revision 208322] (GNU Tools for ARM Embedded Processors)
Is there a way to update PIO’s toolchain to a newer version or Is this a mixup on my end, somewhere?
Does PIO already support aarch64
at the moment, or am I being too optimistic / impatient / eager?
-jcw
