Troubleshooting: compiler can't see share libraries typically installed in standard Arduino install or in platformio install
Hi folks,
I’m a newbie to Platformio, with a lot of experience in the Arduino IDE, which isn’t saying much. I’ve been running into this problem with platformio and the Arduino Yun. I run Linux Min 17.3, and all the avr libraries are installed, including libc. The Yun calls functions from Bridge.h, which in the Arduino 1.6.8 install, resides in $HOMEDIR/bin/arduino-1.6.8/libraries. In the Platformio install, in my .platformio directory tree is as follows.
~/.platformio/packages/framework-arduinoavr/libraries $ ls -l
total 104
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Bridge
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 __cores__
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 EEPROM
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Esplora
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Ethernet
drwxrwx--- 6 klaks klaks 4096 May 19 12:50 Firmata
drwxrwx--- 5 klaks klaks 4096 Apr 28 10:51 GSM
drwxrwx--- 3 klaks klaks 4096 May 19 12:50 HID
drwxrwx--- 3 klaks klaks 4096 May 19 12:50 Keyboard
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 LiquidCrystal
drwxrwx--- 3 klaks klaks 4096 May 19 12:50 Mouse
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Robot_Control
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 RobotIRremote
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Robot_Motor
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Scheduler
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 SD
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Servo
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 SoftwareSerial
drwxrwx--- 3 klaks klaks 4096 May 19 12:50 SpacebrewYun
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 SPI
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Stepper
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Temboo
drwxrwx--- 5 klaks klaks 4096 May 19 12:50 TFT
drwxrwx--- 4 klaks klaks 4096 Apr 28 10:51 USBHost
drwxrwx--- 5 klaks klaks 4096 Apr 28 10:51 WiFi
drwxrwx--- 4 klaks klaks 4096 May 19 12:50 Wire
This is identical to my arduino-1.6.8 install, which is:
 ~/bin/arduino-1.6.8/libraries $ ls -l
total 72
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Bridge
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Esplora
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Ethernet
drwxr-xr-x 6 klaks klaks 4096 Apr 23 22:29 Firmata
drwxr-xr-x 5 klaks klaks 4096 Apr 23 22:29 GSM
drwxr-xr-x 3 klaks klaks 4096 Apr 23 22:29 Keyboard
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 LiquidCrystal
drwxr-xr-x 3 klaks klaks 4096 Apr 23 22:29 Mouse
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Robot_Control
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 RobotIRremote
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Robot_Motor
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 SD
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Servo
drwxr-xr-x 3 klaks klaks 4096 Apr 23 22:29 SpacebrewYun
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Stepper
drwxr-xr-x 4 klaks klaks 4096 Apr 23 22:29 Temboo
drwxr-xr-x 5 klaks klaks 4096 Apr 23 22:29 TFT
drwxr-xr-x 5 klaks klaks 4096 Apr 23 22:29 WiFi
klaks@helix ~/bin/arduino-1.6.8/libraries $
And is in directory trees in both the Arduino-1.6.8 and the Platformio directory’s reveal the same tree.
Here’s the Arduino 1.6.8 tree
klaks@helix ~/bin/arduino-1.6.8/libraries/Bridge/src $ ls -l
total 96
-rw-r--r-- 1 klaks klaks 3858 Mar  8 11:07 BridgeClient.cpp
-rw-r--r-- 1 klaks klaks 2014 Mar  8 11:07 BridgeClient.h
-rw-r--r-- 1 klaks klaks 7166 Mar  8 11:07 Bridge.cpp
-rw-r--r-- 1 klaks klaks 3791 Mar  8 11:07 Bridge.h
-rw-r--r-- 1 klaks klaks 1632 Mar  8 11:07 BridgeServer.cpp
-rw-r--r-- 1 klaks klaks 1419 Mar  8 11:07 BridgeServer.h
-rw-r--r-- 1 klaks klaks 4532 Mar  8 11:07 BridgeUdp.cpp
-rw-r--r-- 1 klaks klaks 2092 Mar  8 11:07 BridgeUdp.h
-rw-r--r-- 1 klaks klaks 3318 Mar  8 11:07 Console.cpp
-rw-r--r-- 1 klaks klaks 1795 Mar  8 11:07 Console.h
-rw-r--r-- 1 klaks klaks 6189 Mar  8 11:07 FileIO.cpp
-rw-r--r-- 1 klaks klaks 3384 Mar  8 11:07 FileIO.h
-rw-r--r-- 1 klaks klaks 4485 Mar  8 11:07 HttpClient.cpp
-rw-r--r-- 1 klaks klaks 2066 Mar  8 11:07 HttpClient.h
-rw-r--r-- 1 klaks klaks 1838 Mar  8 11:07 Mailbox.cpp
-rw-r--r-- 1 klaks klaks 1705 Mar  8 11:07 Mailbox.h
-rw-r--r-- 1 klaks klaks 3213 Mar  8 11:07 Process.cpp
-rw-r--r-- 1 klaks klaks 1942 Mar  8 11:07 Process.h
-rw-r--r-- 1 klaks klaks  986 Mar  8 11:07 YunClient.h
-rw-r--r-- 1 klaks klaks  986 Mar  8 11:07 YunServer.h
And here's the platformio tree
klaks@helix ~/.platformio/packages/framework-arduinoavr/libraries/Bridge/src $ ls -l
total 96
-rwxrwx--- 1 klaks klaks 3858 Mar  8 10:07 BridgeClient.cpp
-rwxrwx--- 1 klaks klaks 2014 Mar  8 10:07 BridgeClient.h
-rwxrwx--- 1 klaks klaks 7166 Mar  8 10:07 Bridge.cpp
-rwxrwx--- 2 klaks klaks 3791 Mar  8 10:07 Bridge.h
-rwxrwx--- 1 klaks klaks 1632 Mar  8 10:07 BridgeServer.cpp
-rwxrwx--- 1 klaks klaks 1419 Mar  8 10:07 BridgeServer.h
-rwxrwx--- 1 klaks klaks 4532 Mar  8 10:07 BridgeUdp.cpp
-rwxrwx--- 1 klaks klaks 2092 Mar  8 10:07 BridgeUdp.h
-rwxrwx--- 1 klaks klaks 3318 Mar  8 10:07 Console.cpp
-rwxrwx--- 2 klaks klaks 1795 Mar  8 10:07 Console.h
-rwxrwx--- 1 klaks klaks 6189 Mar  8 10:07 FileIO.cpp
-rwxrwx--- 1 klaks klaks 3384 Mar  8 10:07 FileIO.h
-rwxrwx--- 1 klaks klaks 4485 Mar  8 10:07 HttpClient.cpp
-rwxrwx--- 1 klaks klaks 2066 Mar  8 10:07 HttpClient.h
-rwxrwx--- 1 klaks klaks 1838 Mar  8 10:07 Mailbox.cpp
-rwxrwx--- 1 klaks klaks 1705 Mar  8 10:07 Mailbox.h
-rwxrwx--- 1 klaks klaks 3213 Mar  8 10:07 Process.cpp
-rwxrwx--- 2 klaks klaks 1942 Mar  8 10:07 Process.h
-rwxrwx--- 1 klaks klaks  986 Mar  8 10:07 YunClient.h
-rwxrwx--- 1 klaks klaks  986 Mar  8 10:07 YunServer.h
You can see Bridge.h is in both directories which are searched under the Arduino IDE. When I run this program for the Yun, which calls for Bridge.h:
```cpp
/* The console program allows the user to see that their keyboard inputs and screen outputs
 *  when in ssh mode lights up digital LED pin 13
 *  To make this work, first in the arduino IDE, select Tools --> Port --> Arduino Yun
 *  Then, in a terminal, type in 'ssh root@yourYunsName.local 'telnet localhost 6571'
 *  Hit enter
 *  It should come with the printout "You're connected to the Console!!!!"
 *  In the void loop section, if the incoming byte is H, it'll light up pin 13, and if it's
 *  L it'll turn off pin 13
/* Seems that platformio requires this library which I think comes from
 * arduino1.6.8/hardware/arduino/avr/cores/arduino in the Arduino director
 * and on the platformio install directory, .platformio/packages/framework-arduinoavr/cores/arduino
 * indicating that both the ArduinoIDE and the platformio program are able to access
 * their cores/arduino directories
/* Console.h is required to begin serial communications.
 * Bridge is required to talk across the Yun's microcontroller and the embedded linux system on the yun
 * Both files are located in the Arduino IDE in arduino1.6.8/libraries/Bridge, and in the platformio system,
 * in .platformio/packages/framework-arduinoavr/libraries/Bridge
 * So far, it's not getting compiled and linked in the platformio system
#include <Console.h>
#include <Bridge.h>
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
  // initialize serial communication:
  Bridge.begin();
  Console.begin();
  while (!Console){
    ; // wait for Console port to connect.
  Console.println("You're connected to the Console!!!!");
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // see if there's incoming serial data:
  if (Console.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Console.read();
    // if it's a capital H (ASCII 72), turn on the LED:
    if (incomingByte == 'H') {
      digitalWrite(ledPin, HIGH);
    // if it's an L (ASCII 76) turn off the LED:
    if (incomingByte == 'L') {
      digitalWrite(ledPin, LOW);
  delay(100);
Which has this platformio.ini file,
```ini
# Project Configuration File
# A detailed documentation with the EXAMPLES is located here:
# http://docs.platformio.org/en/latest/projectconf.html
# A sign `#` at the beginning of the line indicates a comment
# Comment lines are ignored.
# Simple and base environment
# [env:mybaseenv]
# platform = %INSTALLED_PLATFORM_NAME_HERE%
# framework =
# board =
# Automatic targets - enable auto-uploading
# targets = upload
[env:yun]
board = yun
I get this.
klaks@helix ~/Programming/AVR/Arduino/Yun/YunConsole $ ls -l
total 12
drwxr-xr-x 2 klaks klaks 4096 May 20 11:23 lib
-rw-r--r-- 1 klaks klaks  490 May 20 11:33 platformio.ini
drwxr-xr-x 2 klaks klaks 4096 May 20 11:31 src
klaks@helix ~/Programming/AVR/Arduino/Yun/YunConsole $ pio run
[Fri May 20 11:35:05 2016] Processing yun (platform: atmelavr, board: yun, framework: arduino)
avr-gcc -o .pioenvs/yun/src/main.o -c -std=gnu11 -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_YUN -DUSB_VID=0x2341 -DUSB_PID=0x0041 "-DUSB_PRODUCT=\"Arduino Yun\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO=10608 -DPLATFORMIO=020901 -I.pioenvs/yun/FrameworkArduino -I.pioenvs/yun/FrameworkArduinoVariant -I.pioenvs/yun/Bridge src/main.c
avr-ar rcs .pioenvs/yun/libFrameworkArduinoVariant.a
avr-ranlib .pioenvs/yun/libFrameworkArduinoVariant.a
avr-g++ -o .pioenvs/yun/FrameworkArduino/CDC.o -c -fno-exceptions -fno-threadsafe-statics -std=gnu++11 -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_YUN -DUSB_VID=0x2341 -DUSB_PID=0x0041 "-DUSB_PRODUCT=\"Arduino Yun\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO=10608 -I.pioenvs/yun/FrameworkArduino -I.pioenvs/yun/FrameworkArduinoVariant .pioenvs/yun/FrameworkArduino/CDC.cpp
avr-g++ -o .pioenvs/yun/FrameworkArduino/HardwareSerial.o -c -fno-exceptions -fno-threadsafe-statics -std=gnu++11 -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_YUN -DUSB_VID=0x2341 -DUSB_PID=0x0041 "-DUSB_PRODUCT=\"Arduino Yun\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO=10608 -I.pioenvs/yun/FrameworkArduino -I.pioenvs/yun/FrameworkArduinoVariant .pioenvs/yun/FrameworkArduino/HardwareSerial.cpp
avr-g++ -o .pioenvs/yun/FrameworkArduino/HardwareSerial0.o -c -fno-exceptions -fno-threadsafe-statics -std=gnu++11 -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO_ARCH_AVR -DARDUINO_AVR_YUN -DUSB_VID=0x2341 -DUSB_PID=0x0041 "-DUSB_PRODUCT=\"Arduino Yun\"" -DUSB_MANUFACTURER=\"Arduino\" -DARDUINO=10608 -I.pioenvs/yun/FrameworkArduino -I.pioenvs/yun/FrameworkArduinoVariant .pioenvs/yun/FrameworkArduino/HardwareSerial0.cpp
In file included from .pioenvs/yun/FrameworkArduino/Print.h:27:0,
from .pioenvs/yun/FrameworkArduino/Stream.h:26,
from .pioenvs/yun/Bridge/Bridge.h:27,
from .pioenvs/yun/Bridge/Console.h:22,
from src/main.c:27:
.pioenvs/yun/FrameworkArduino/Printable.h:25:1: error: unknown type name 'class'
class Print;
.pioenvs/yun/FrameworkArduino/Printable.h:33:1: error: unknown type name 'class'
class Printable
.pioenvs/yun/FrameworkArduino/Printable.h:34:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from .pioenvs/yun/FrameworkArduino/Stream.h:26:0,
from src/main.c:27:
.pioenvs/yun/FrameworkArduino/Print.h:34:1: error: unknown type name 'class'
class Print
.pioenvs/yun/FrameworkArduino/Print.h:35:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from .pioenvs/yun/Bridge/Bridge.h:27:0,
from src/main.c:27:
.pioenvs/yun/FrameworkArduino/Stream.h:49:1: error: unknown type name 'class'
class Stream : public Print
.pioenvs/yun/FrameworkArduino/Stream.h:49:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from .pioenvs/yun/Bridge/Console.h:22:0,
from src/main.c:27:
.pioenvs/yun/Bridge/Bridge.h:29:1: error: unknown type name 'class'
class BridgeClass {
.pioenvs/yun/Bridge/Bridge.h:29:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
class BridgeClass {
.pioenvs/yun/Bridge/Bridge.h:96:1: error: unknown type name 'class'
class SerialBridgeClass : public BridgeClass {
.pioenvs/yun/Bridge/Bridge.h:96:25: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
.pioenvs/yun/Bridge/Bridge.h:112:1: error: unknown type name 'SerialBridgeClass'
extern SerialBridgeClass Bridge;
.pioenvs/yun/Bridge/Bridge.h:120:52: error: expected ';', ',' or ')' before '=' token
extern void checkForRemoteSketchUpdate(uint8_t pin = 7);
In file included from .pioenvs/yun/Bridge/Bridge.h:125:0,
from src/main.c:27:
.pioenvs/yun/Bridge/Process.h:24:1: error: unknown type name 'class'
class Process : public Stream {
.pioenvs/yun/Bridge/Process.h:24:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
In file included from src/main.c:27:0:
.pioenvs/yun/Bridge/Console.h:24:1: error: unknown type name 'class'
class ConsoleClass : public Stream {
.pioenvs/yun/Bridge/Console.h:24:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
.pioenvs/yun/Bridge/Console.h:69:1: error: unknown type name 'ConsoleClass'
extern ConsoleClass Console;
src/main.c: In function 'setup':
src/main.c:35:9: error: request for member 'begin' in something not a structure or union
Bridge.begin();
src/main.c:36:10: error: request for member 'begin' in something not a structure or union
Console.begin();
src/main.c:41:10: error: request for member 'println' in something not a structure or union
src/main.c: In function 'loop':
src/main.c:48:14: error: request for member 'available' in something not a structure or union
src/main.c:50:27: error: request for member 'read' in something not a structure or union
scons: *** [.pioenvs/yun/src/main.o] Error 1
================================================ [ ERROR ] Took 2.43 seconds ================================================
It compiles fine on the ArduinoIDE. Is there a way to get platformio to access the libraries via the platformio.ini file, or from what I've read so far, is this a bug that's stlll being worked on? I would think that since those libraries are installed with the standard Arduino package, it should also be seen in the platformio package as well. That said, I have run into a few situations on the ArduinoIDE where a few programs also couldn't see Bridge.h or Console.h, and as a hack, I had to copy those library files into the same project directory. I'm not a fan of that hack. This is not consistent, and in the case of this program, it compiles just fine on the Arduino IDE.
I also have a ton of ~/sketchbook/libraries, which I'm really keen on using, but I can't seem to include in platformio. And a lot of them are not listed in the platformio library manager, and I do need to use them.
Please advise.
Please rename it to main.cpp :blush:
It does the same with main.cpp.
I renamed it to main.c to test, and the same result.
Ah crap, nope that actually worked.
Still, there is the unresolved problem of accessing other libraries outside of the .platformio installation. From what I’ve read, that’s being worked on, or it’s not possible with platformio?
You can place global libraries to ~/.platformio/libs and use in projects. PlatformIO will automatically detect them and build.
here You can read topic how to organize libraries:
I just make symlinks in ~/.platformio/lib
