Hi, I’m developing an application using ESP8266 and Platformio and, since it is the first time I try to create a flash filesystem, I’m a bit lost here.
I’m having trouble understanding what’s going wrong while clicking on “Build Filesystem Image” in Platformio IDE. The data
dir is already populated with some text files and it is at the same level as ‘src’, like it should be expected (at least so I read). It fails with error -8
like this:
> Executing task in folder pwc_esp8266: platformio run --target buildfs --environment esp01_1m <
Processing esp01_1m (platform: espressif8266; board: esp01_1m; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 (3.2.0) > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210628 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 40 compatible libraries
|-- <Blynk> 1.0.1
| |-- <ESP8266WiFi> 1.0
|-- <Adafruit Unified Sensor> 1.1.4
|-- <DHT sensor library> 1.4.2
|-- <LittleFS> 0.1.0
Building file system image from 'data' directory to .pio/build/esp01_1m/littlefs.bin
*** [.pio/build/esp01_1m/littlefs.bin] Error -8
=========================== [FAILED] Took 0.85 seconds ===========================
Environment Status Duration
esp01_1m FAILED 00:00:00.848
===================== 1 failed, 0 succeeded in 00:00:00.848 =====================
The terminal process "platformio 'run', '--target', 'buildfs', '--environment', 'esp01_1m'" terminated with exit code: 1.
I don’t think it is a config error, since I correctly set board_build.filesystem
and board_build.ldscript
variables in platformio.ini:
[env:esp01_1m]
platform = espressif8266
board = esp01_1m
board_build.ldscript = eagle.flash.1m.ld
blynkkk/Blynk @ ^1.0.1
adafruit/Adafruit Unified Sensor @ ^1.1.4
adafruit/DHT sensor library @ ^1.4.2
The error is exaclty the same if I choose spiffs
instead of littlefs
|-- <Blynk> 1.0.1
|-- <LittleFS> 0.1.0
Building file system image from 'data' directory to .pio/build/esp01_1m/spiffs.bin
*** [.pio/build/esp01_1m/spiffs.bin] Error -8
=========================== [FAILED] Took 1.03 seconds ===========================
esp01_1m FAILED 00:00:01.031
===================== 1 failed, 0 succeeded in 00:00:01.031 =====================
Can anyone help me on this? I checked and the application mklittlefs
does exist in .platformio/packages/tool-mklittlefs/
so I’m suspecting there is something wrong about the “Build Filesystem Image” IDE option (?!). Really stuck here
