bliker库中的
未定义标识符 “BLINKER_LOG”
(modaterator: chinese->english autotranslate): “Unknown identifier “BLINKER_LOG” in the blinker library error”.
bliker库中的
You might have installed the wrong library. Your platformio.ini
should contain
lib_deps = 2519
And for example code, see PlatformIO Registry. Unfortunately there seems to be a library with the same name (here)… If you have installed the wrong library you should delete the .pio\libdeps
folder of you project and remove it from the global library repository.
