Hello, i am getting the following error while compiling in my Macbook M1
Users/$$$$$/.platformio/packages/toolchain-gccarmnoneeabi@1.70201.0/arm-none-eabi/include/termios.h:4:10: fatal error: sys/termios.h: No such file or directory
When i check in the sys folder of toolchain-gccarmnoneeabi indeed there is no termios.h file, but i do have one in my OS (which has different identifiers)
I checked and i have Rossetta installed, so i don’t think it’s related to that. Any ideas?
Mhmm okay I get an idea of why that is now. The file is in gd2-lib/spidriver.cpp at master · jamesbowman/gd2-lib · GitHub. I think the entire pc/
folder should not be compiled for an embedded target.
In the compilation log, do you see PlatformIO trying to compile anything from that pc/
folder, like spidriver.cpp?
Yes exactly! that file is the problem. I am still not using the arduino board, i am just trying to see if it compiles but it gives me that error
With what microcontroller are you using that Gameduino 2 “shield”? Based on your post it must be an ARM based one (Teensy X), but which board = ..
do you have selected in the platformio.ini
I have “due” board selected. The project is very very poorly documented. Some of the other platformio.ini files even had a “duelow” and “duehigh” boards that i replaced with “due” because i could’t find any boards with those names
Well yes the problem is that PlatformIO is trying to compile a file that should not be compiled for the embedded target (anything in PC).
Usually a library has a library.json
(Redirecting...) that controls such build options. I have created a library.json
with
"name": "gd2-lib",
"version": "1.3.4",
"repository":
"type": "git",
"url": "https://github.com/jamesbowman/gd2-lib.git"
"build": {
"srcDir": ".",
"srcFilter": "+<*> -<**/pc>"
that works around this problems and allowed me to compile for a Teensy.
A Due is a different story. The library / examples e.g. need EEPROM.h
, which is not available by default in the Due’s Arduino core (but fill-in libraries like GitHub - PhiJu5/DueFlashStorage: Due EEPROM emulation exist, but they use a different header name). Did you already encounter / solve that?
If the original platformio.ini
referenced duehigh
and duelow
then there must be a duelow.json
etc. JSON file somewhere. Is that there?
For reference, when I do
[env:teensy40]
platform = teensy
board = teensy40
https://github.com/maxgerhardt/gd2-lib
with a src/main.cpp
filled with the content of gd2-lib/helloworld.ino at master · jamesbowman/gd2-lib · GitHub, it compiles.
Calculating size .pio\build\teensy40\firmware.elf
Building .pio\build\teensy40\firmware.hex
teensy_size: Memory Usage on Teensy 4.0:
teensy_size: FLASH: code:24812, data:2968, headers:9080 free for files:1994756
teensy_size: RAM1: variables:3680, code:23104, padding:9664 free for local variables:487840
teensy_size: RAM2: variables:12384 free for malloc/new:511904
============================================= [SUCCESS] Took 1.39 seconds =============================================
I’ll try with that library.json trick
I see i’m going trhough the path my predessesor went through. He actually forked that Repo and made this one. And i already installed that.
This project had different github repos for each part of the project. Now i am just trying to compile the “OS” that was created. Other repos did have a platformio.ini, and some of those had a “duelow” board selected. But the one i am trying to compile had no more files than the .cpp and .h
Okay, I definitely got the hello world example compiling for a Due with the latest library version. The EEPROM.h include was just from an example which didn’t need it after all. What was holding it back was a type conversion error for SPI.transfer()
between a char*
and a byte*
(aka unsigned char*
With
[env:due]
platform = atmelsam
board = due
I can get the hello-world.ino example linked above but without the #include <EEPROM.h>
line to build correctly.
Linking .pio\build\due\firmware.elf
Checking size .pio\build\due\firmware.elf
RAM: [ ] 2.8% (used 2728 bytes from 98304 bytes)
Flash: [ ] 2.9% (used 15436 bytes from 524288 bytes)
Building .pio\build\due\firmware.bin
============================================= [SUCCESS] Took 11.49 seconds =============================================
My fork already includes the library.json
which ignores the pc/
folder.
Yeah, i think that did the trick. I’m not 100% sure just because now there are other issues coming up. Let me check again
Yes, i think it worked. There’s just so many instalation issues. It’s asking me for dependencies i already installed. This is too much for a platformio/arduino newbie.
But i think we got this issue fixed. Thanks again!!
Do you have the source code for the application and the target board & version information / original files / libraries uploaded somewhere? Or they publishable?
It’s actually a private repository. I think i am going to have to find the previous developer because now i just found out he defined a debug.h file that isn’t anywhere and is super integrated in the code.
But even if i could send you the code it does give much information. I think i have conceptual things i need to understand about platformio and arduino, but if i can boil them down to a question ill surely post it here
