"tone" for buzzer ? No acceptable?
Seriously sucks. I took the tones out of that simple script that just lights stinking LEDs, and it’s forced me to add BusIO to the /lib. and now this?
I hate it. Where did all of this new junk come from? None of that was a problem the first three thousand times I got a library to work.
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino)
PLATFORM: Espressif 32 1.12.4 > Espressif ESP32 Dev Module
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
 - framework-arduinoespressif32 3.10004.200129 (1.0.4)
 - tool-esptoolpy 1.20600.0 (2.6.0)
 - tool-mkspiffs 2.230.0 (2.30)
 - toolchain-xtensa32 2.50200.80 (5.2.0)
Found 32 compatible libraries
|-- <Adafruit GFX Library> 1.10.0
|   |-- <Adafruit BusIO> 1.4.1
|   |   |-- <Wire> 1.0.1
|   |   |-- <SPI> 1.0
|   |-- <SPI> 1.0
|   |-- <Wire> 1.0.1
|-- <Adafruit SSD1306> 2.3.1
|   |   |   |-- <Wire> 1.0.1
|   |   |   |-- <SPI> 1.0
|   |   |-- <SPI> 1.0
|   |   |-- <Wire> 1.0.1
|   |-- <SPI> 1.0
|   |-- <Wire> 1.0.1
|-- <timelib>
|-- <Tone> 0.0.1
|-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\libba3\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\lib5a1\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\lib6d3\Adafruit BusIO\Adafruit_BusIO_Register.cpp.o
Archiving .pio\build\esp32dev\lib5a1\libSPI.a
Compiling .pio\build\esp32dev\lib6d3\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
Compiling .pio\build\esp32dev\lib6d3\Adafruit BusIO\Adafruit_I2CRegister.cpp.o
Archiving .pio\build\esp32dev\libba3\libWire.a
Compiling .pio\build\esp32dev\lib6d3\Adafruit BusIO\Adafruit_SPIDevice.cpp.o
Compiling .pio\build\esp32dev\libf23\Adafruit GFX Library\Adafruit_GFX.cpp.o
Compiling .pio\build\esp32dev\libf23\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:3:145: error: ISO C++ forbids declaration of 'Adafruit_I2CRegister' with no type [-fpermissive]
 Adafruit_I2CRegister::Adafruit_I2CRegister(Adafruit_I2CDevice *device, uint16_t reg_addr, uint8_t width, uint8_t bitorder, uint8_t address_width) {
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:3:145: error: no 'int Adafruit_BusIO_Register::Adafruit_I2CRegister(Adafruit_I2CDevice*, uint16_t, uint8_t, uint8_t, uint8_t)' member function declared in class 'Adafruit_BusIO_Register'
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::write(uint8_t*, uint8_t)':
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:14:9: error: '_device' was not declared in this scope
   if (! _device->write(buffer, len, true, addrbuffer, _addrwidth)) {
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::write(uint32_t, uint8_t)':
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:29:9: error: '_bitorder' was not declared in this scope
     if (_bitorder == LSBFIRST) {
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'uint32_t Adafruit_BusIO_Register::read()':
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:49:10: error: '_bitorder' was not declared in this scope
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::read(uint8_t*, uint8_t)':
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:62:9: error: '_device' was not declared in this scope
   if (! _device->write_then_read(_buffer, 1, buffer, len)) {
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: In member function 'bool Adafruit_BusIO_Register::read(uint16_t*)':
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:73:7: error: '_bitorder' was not declared in this scope
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp: At global scope:
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:105:106: error: ISO C++ forbids declaration of 'Adafruit_I2CRegisterBits' with no type [-fpermissive]
 Adafruit_I2CRegisterBits::Adafruit_I2CRegisterBits(Adafruit_I2CRegister *reg, uint8_t bits, uint8_t shift) {
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:105:106: error: no 'int Adafruit_BusIO_RegisterBits::Adafruit_I2CRegisterBits(Adafruit_I2CRegister*, uint8_t, uint8_t)' member function declared in class 'Adafruit_BusIO_RegisterBits'
lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:117:6: error: prototype for 'void Adafruit_BusIO_RegisterBits::write(uint32_t)' does not match any in class 'Adafruit_BusIO_RegisterBits'
 void Adafruit_I2CRegisterBits::write(uint32_t data) {
In file included from lib\Adafruit BusIO/Adafruit_I2CRegister.h:1:0,
                 from lib\Adafruit BusIO\Adafruit_I2CRegister.cpp:1:
lib\Adafruit BusIO/Adafruit_BusIO_Register.h:66:8: error: candidate is: bool Adafruit_BusIO_RegisterBits::write(uint32_t)
   bool write(uint32_t value);
*** [.pio\build\esp32dev\lib6d3\Adafruit BusIO\Adafruit_I2CRegister.cpp.o] Error 1
==================================================================================================== [FAILED]
