I have been trying TI LaunchPad (Tiva C) tm4c123 (80MHz) with VS Code and PlatformIO. Could not upload the energia blink example to the board after successful compiling. The error message is as follows.
Processing lptm4c1230c3pm (platform: titiva; board: lptm4c1230c3pm; framework: energia)
Verbose mode can be enabled via -v, --verbose
option
CONFIGURATION:
PLATFORM: TI TIVA > TI LaunchPad (Tiva C) w/ tm4c123 (80MHz)
HARDWARE: LPTM4C1230C3PM 80MHz 32KB RAM (256KB Flash)
DEBUG: CURRENT(ti-icdi) ON-BOARD(ti-icdi)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 22 compatible libraries
Scanning dependencies…
Checking size .pioenvs\lptm4c1230c3pm\firmware.elf
Memory Usage → Redirecting...
DATA: [ ] 1.6% (used 520 bytes from 32768 bytes)
PROGRAM: [ ] 0.9% (used 2324 bytes from 262144 bytes)
Configuring upload protocol…
Uploading .pioenvs\lptm4c1230c3pm\firmware.bin
‘openocd’ is not recognized as an internal or external command,
operable program or batch file.
*** [upload] Error 1
Please help, thanks!
