New install of VS Code with Platform IO extension on Win10 with domain connected user account.
Create an ESP32 project from PIO
Try to build project.
Executing task: C:\Users\me.platformio\penv\Scripts\platformio.exe run <
The terminal shell CWD “\DOMAINSERVER\RedirectedFolders\me\My Documents\PlatformIO\Projects\WAYO_CD” does not exist
launch.json had
“executable”: “/DOMAINSERVER/RedirectedFolders/me/My Documents/PlatformIO/Projects/WAYO_CD/.pio/build/esp32dev/firmware.elf”,
“toolchainBinDir”: “C:/Users/me/.platformio/packages/toolchain-xtensa32/bin”,
I changed /DOMAINSERVER/RedirectedFolders to C:/me :no change
Tried setting terminal.integrated.cwd to c:\temp : no change
Disabled PIO :no change
I can’t find where VSC is getting the /DOMAINSERVER/RedirectedFolders/me from
- note DOMAINSERVER and me are redacted names.
I have been able to create a project where if I override the ‘Location’ when creating a new project to a local folder (ie c:\app\test) then I could get it to compile.
Downloading test projects though places them in the redirect folder which causes the compile error.
I tried changing the PIO default folder with
pio settings set projects_dir /new/path/projects/dir
This fixed one project but not another.
VS Code version: Code 1.40.2
OS version: Windows_NT x64 10.0.17763
