This is the result
To the platformio.ini not in the terminal
Do you mean I add build_flags = -DCORE_DEBUG_LEVEL=5 to Arduino IDE application, then upload it to EPS8266?
In the PlatformIO project, not in the Arduino IDE, you have a file called platformio.ini
where you can add the line build_flags = -DCORE_DEBUG_LEVEL=5
. If you are using the Arduino IDE, use Tools → Core Debug Level → 5 (Verbose) option and reupload
