I just burned the optiboot on my printer, but Im getting errors trying to compile the TH3D software to Anet E12.
Here is what I get:
> Executing task: C:\Users\Artur\.platformio\penv\Scripts\platformio.exe run <
Processing melzi_optiboot_optimized (platform: atmelavr; board: sanguino_atmega1284p; framework: arduino)
Error: Build environment 'melzi_optiboot_optimized' is incompatible with BOARD_ANET_10. Use one of these: sanguino1284p, sanguino1284p_optimized
============== [FAILED] Took 1.70 seconds ==============
Environment Status Duration
melzi_optiboot_optimized FAILED 00:00:01.701
======== 1 failed, 0 succeeded in 00:00:01.701 ========
The terminal process "C:\Users\Artur\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
I was following this guide https://www.th3dstudio.com/hc/downloads/unified-2-firmware/anet/anet-e12-firmware-melzi-board/
I already uncomented the “#define ANET_E12
What do I do?
