TFT help, please
I’m beside myself. I’m coming to hate Arduino.
I’m sure it’s all really smart writing, but it only passes Arduino muster.
NONE of this is declared, apparently.
No trouble with any of the libraries. Just the juvenile code.
Somebody should sue them. They’re causing damage.
I have the LI9486 shield. I’ve given up on the other TFT, because it only connects along the long Mega rail (I have a shield, but it has built-in resistors), and none of the examples I’ve found make any sense.
#include <Adafruit_GFX.h>    // Core graphics library
#include <MCUFRIEND_kbv.h>   // Hardware-specific library
MCUFRIEND_kbv tft;
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
#include <FreeDefaultFonts.h>
#define BLACK   0x0000
#define RED     0xF800
#define GREEN   0x07E0
#define WHITE   0xFFFF
#define GREY    0x8410
void setup(void)
    Serial.begin(9600);
    uint16_t ID = tft.readID();
    Serial.println("Example: Font_simple");
    Serial.print("found ID = 0x");
    Serial.println(ID, HEX);
    if (ID == 0xD3D3) ID = 0x9481; //force ID if write-only display
    tft.begin(ID);
    tft.setRotation(0);
void loop(void)
    tft.fillScreen(BLACK);
    showmsgXY(20, 10, 1, NULL, "System x1");
    showmsgXY(20, 24, 2, NULL, "System x2");
    showmsgXY(20, 60, 1, &FreeSans9pt7b, "FreeSans9pt7b");
    showmsgXY(20, 80, 1, &FreeSans12pt7b, "FreeSans12pt7b");
    showmsgXY(20, 100, 1, &FreeSerif12pt7b, "FreeSerif12pt7b");
    showmsgXY(20, 120, 1, &FreeSmallFont, "FreeSmallFont");
    showmsgXY(5, 180, 1, &FreeSevenSegNumFont, "01234");
    showmsgXY(5, 190, 1, NULL, "System Font is drawn from topline");
    tft.setTextColor(RED, GREY);
    tft.setTextSize(2);
    tft.setCursor(0, 220);
    tft.print("7x5 can overwrite");
    delay(1000);
    tft.print("if background set");
    delay(1000);
    showmsgXY(5, 260, 1, &FreeSans9pt7b, "Free Fonts from baseline");
    showmsgXY(5, 285, 1, &FreeSans9pt7b, "Free Fonts transparent");
    delay(1000);
    showmsgXY(5, 285, 1, &FreeSans9pt7b, "Free Fonts XXX");
    delay(1000);
    showmsgXY(5, 310, 1, &FreeSans9pt7b, "erase backgnd with fillRect()");
    delay(10000);
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
    int16_t x1, y1;
    uint16_t wid, ht;
    tft.drawFastHLine(0, y, tft.width(), WHITE);
    tft.setFont(f);
    tft.setCursor(x, y);
    tft.setTextColor(GREEN);
    tft.setTextSize(sz);
    tft.print(msg);
    delay(1000);
I’m not sure what you’re asking. Does the firmware not compile? Does it not work? On which exact are hardware you putting on your shield? platformio.ini?
Ugh.
Nothing is declared.
This is too tedious. I maybe withdraw this.
Maybe you could visually scan it and tell me if all of the functions that have to be declared are void?
TestFillScreen
TestText…
Ugh.
And I’m supposed to be focused on ISS.
Works perfectly fine when declaring all needed libraries.
grafik
platformio.ini
[env:uno]
board = uno
    Wire
    SPI
    adafruit/Adafruit GFX Library @ ^1.10.3
    adafruit/Adafruit BusIO @ ^1.6.0
    https://github.com/prenticedavid/MCUFRIEND_kbv/archive/master.zip
Code tweak: Over the implementation of setup(), one must place
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg);
to pre-declare the prototype of the function declared downwards.
