TFT_eSPI, TFT_eWidget and ILI9488
I have been using Bodmers excellent TFT_eSPI library with various TFT displays for years, and it works great.
Now I have found his TFT_eWidget library, for buttons, sliders etc. and I am setting upp 6 vertical sliders with the display in landscape mode (480x320). Because of the
relatively small physical size of the screen, ( ~ 80x55 mm), this makes the sliders rather short, and difficult to adjust.
If I use a stylus to move the sliders, they move in a smooth, stable way up and down, but when I use my finger they get very “shaky” and unstable in the way they move.
I do realize that this is because my finger touches several coordinates at the same time.
TFT_eWidget is very configurable in terms of slider orientation, size, width, knobSize etc. etc. so I have set the size of the slider knob to be the same size as my fingertip (which is very easy to do).
Now I need a little routine that checks if my finger is within this area, and if so, then dont move the slider, and when I move the finger I want the slider to move in a smooth, stable way.
(I’m using a ESP32S2 with a ILI9488 4" SPI TFT display)
This is the TFT_eWidget slider example from Bodmer with one horisontal slider and one vertical :
// Slider widget demo, requires display with touch screen
// Requires widget library here:
// https://github.com/Bodmer/TFT_eWidget
#include "FS.h"
#include "Free_Fonts.h" // Include the header file attached to this sketch
#include <TFT_eSPI.h>
#include <TFT_eWidget.h>           // Widget library
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite knob = TFT_eSprite(&tft); // Sprite for the slide knob
#define CALIBRATION_FILE "/TouchCalData1"
#define REPEAT_CAL false
SliderWidget s1 = SliderWidget(&tft, &knob);    // Slider 1 widget
SliderWidget s2 = SliderWidget(&tft, &knob);    // Slider 2 widget
  tft.begin();
  tft.setRotation(0);
  tft.fillScreen(TFT_BLACK);
  tft.setFreeFont(FF18);
  // Calibrate the touch screen and retrieve the scaling factors
  if (REPEAT_CAL) {
    touch_calibrate();
  // Create a parameter set for the slider
  slider_t param;
  // Slider slot parameters
  param.slotWidth = 9;           // Note: ends of slot will be rounded and anti-aliased
  param.slotLength = 200;        // Length includes rounded ends
  param.slotColor = TFT_BLUE;    // Slot colour
  param.slotBgColor = TFT_BLACK; // Slot background colour for anti-aliasing
  param.orientation = H_SLIDER;  // sets it "true" for horizontal
  // Slider control knob parameters (smooth rounded rectangle)
  param.knobWidth = 15;          // Always along x axis
  param.knobHeight = 25;         // Always along y axis
  param.knobRadius = 5;          // Corner radius
  param.knobColor = TFT_WHITE;   // Anti-aliased with slot backgound colour
  param.knobLineColor = TFT_RED; // Colour of marker line (set to same as knobColor for no line)
  // Slider range and movement speed
  param.sliderLT = 0;            // Left side for horizontal, top for vertical slider
  param.sliderRB = 100;          // Right side for horizontal, bottom for vertical slider
  param.startPosition = 50;      // Start position for control knob
  param.sliderDelay = 0;         // Microseconds per pixel movement delay (0 = no delay)
  // Create slider using parameters and plot at 0,0
  s1.drawSlider(0, 0, param);
  // Show bounding box (1 pixel outside slider working area)
  int16_t x, y;    // x and y can be negative
  uint16_t w, h;   // Width and height
  s1.getBoundingRect(&x, &y, &w, &h);     // Update x,y,w,h with bounding box
  tft.drawRect(x, y, w, h, TFT_DARKGREY); // Draw rectangle outline
  // Alternative discrete fns to create/modify same slider - but fn sequence is important...
  s1.createSlider(9, 200, TFT_BLUE, TFT_BLACK, H_SLIDER);
  s1.createKnob(15, 25, 5, TFT_WHITE, TFT_RED);
  s1.setSliderScale(0, 100);
  s1.drawSlider(0, 0);
  delay(1000);
  s1.setSliderPosition(50);
  delay(1000);
  s1.setSliderPosition(100);
  // Update any parameters that are different for slider 2
  param.slotWidth = 4;
  param.orientation = V_SLIDER; // sets it "false" for vertical
  param.knobWidth = 19;
  param.knobHeight = 19;
  param.knobRadius = 19/2; // Half w and h so creates a circle
  param.sliderLT = 200;     // Top for vertical slider
  param.sliderRB = 0;       // Bottom for vertical slider
  param.sliderDelay = 2000; // 2ms per pixel movement delay (movement is blocking until complete)
  s2.drawSlider(0, 50, param);
  s2.getBoundingRect(&x, &y, &w, &h);
  s2.createSlider(4, 200, TFT_BLUE, TFT_BLACK, V_SLIDER);
  s2.createKnob(19, 19, 9, TFT_WHITE, TFT_RED);
  s2.setSliderScale(200, 0, 2000);
  s2.drawSlider(0, 50);
  // Move slider under software control
  delay(1000);
  s2.setSliderPosition(50);
  delay(1000);
  s2.setSliderPosition(100);
  static uint32_t scanTime = millis();
  uint16_t t_x = 9999, t_y = 9999; // To store the touch coordinates
  // Scan for touch every 50ms
  if (millis() - scanTime >= 20) {
    // Pressed will be set true if there is a valid touch on the screen
    if( tft.getTouch(&t_x, &t_y, 250) ) {
      if (s1.checkTouch(t_x, t_y)) {
        Serial.print("Slider 1 = "); Serial.println(s1.getSliderPosition());
      if (s2.checkTouch(t_x, t_y)) {
        Serial.print("Slider 2 = "); Serial.println(s2.getSliderPosition());
  //s1.moveTo(random(101));
  //delay(250);
  //s2.moveTo(random(101));
  //delay(250);
void touch_calibrate()
  uint16_t calData[5];
  uint8_t calDataOK = 0;
  // check file system exists
  if (!LittleFS.begin()) {
    Serial.println("Formating file system");
    LittleFS.format();
    LittleFS.begin();
  // check if calibration file exists and size is correct
  if (LittleFS.exists(CALIBRATION_FILE)) {
    if (REPEAT_CAL)
      // Delete if we want to re-calibrate
      LittleFS.remove(CALIBRATION_FILE);
    else
      File f = LittleFS.open(CALIBRATION_FILE, "r");
      if (f) {
        if (f.readBytes((char *)calData, 14) == 14)
          calDataOK = 1;
        f.close();
  if (calDataOK && !REPEAT_CAL) {
    // calibration data valid
    tft.setTouch(calData);
  } else {
    // data not valid so recalibrate
    tft.setCursor(20, 0);
    tft.setTextFont(2);
    tft.setTextSize(1);
    tft.setTextColor(TFT_WHITE, TFT_BLACK);
    tft.println("Touch corners as indicated");
    tft.setTextFont(1);
    tft.println();
    if (REPEAT_CAL) {
      tft.setTextColor(TFT_RED, TFT_BLACK);
      tft.println("Set REPEAT_CAL to false to stop this running again!");
    tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
    tft.setTextColor(TFT_GREEN, TFT_BLACK);
    tft.println("Calibration complete!");
    // store data
    File f = LittleFS.open(CALIBRATION_FILE, "w");
    if (f) {
      f.write((const unsigned char *)calData, 14);
      f.close();
I have modified it to use 6 vertical sliders. The modifications are :
SliderWidget s3 = SliderWidget(&tft, &knob); // Slider 3 widget
SliderWidget s4 = SliderWidget(&tft, &knob); // Slider 4 widget
SliderWidget s5 = SliderWidget(&tft, &knob); // Slider 5 widget
SliderWidget s6 = SliderWidget(&tft, &knob); // Slider 6 widget
param.slotWidth = 15;
  param.knobWidth = 35;
  param.knobRadius = 5;          // Half w and h so creates a circle
  param.sliderLT = 0;       // Top for vertical slider
  param.sliderRB = 100;     // Bottom for vertical slider
  param.sliderDelay = 200;  //   0 ??  2ms per pixel movement delay
     s1.drawSlider(25, 100, param);
      s1.getBoundingRect(&xw, &yw, &w, &h);
      tft.drawRect(xw, yw, w, h, TFT_DARKGREY);
      s2.drawSlider(115, 100, param);
      s2.getBoundingRect(&xw, &yw, &w, &h);
      s3.drawSlider(185, 100, param);
      s3.getBoundingRect(&xw, &yw, &w, &h);
      s4.drawSlider(255, 100, param);
      s4.getBoundingRect(&xw, &yw, &w, &h);
      s5.drawSlider(345, 100, param);
      s5.getBoundingRect(&xw, &yw, &w, &h);
      s6.drawSlider(420, 100, param);
      s6.getBoundingRect(&xw, &yw, &w, &h);
      tft.drawRect(xw, yw, w, h, TFT_DARKGREY);;
      s1.setSliderPosition(10);
      s2.setSliderPosition(10);
      s3.setSliderPosition(10);
      s4.setSliderPosition(10);
      s5.setSliderPosition(10);
      s6.setSliderPosition(10);
Any ideas how to get the smooth finger slider movement ??
